Best method to jig up rear to weld spring pads? #238989
02/28/09 05:55 PM
02/28/09 05:55 PM
Tampa Florida
dc426 Offline OP
gotta keep'm separated
dc426  Offline OP
Tampa Florida
I've got my 8.75 out and have my Dana setting in the springs. I'm wondering what the best method to weld the spring pads on the housing is. Do I weld them in neutral and add pinion angle after the fact? Or do I try to get the car at ride height with weight on the rear axle and drive shaft in to get the desired angle, then weld them. What is the preferred method?
DC
Re: Best method to jig up rear to weld spring pads? [Re: dc426] #238990
02/28/09 06:11 PM
02/28/09 06:11 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
the second part of your question is your answer....
I am truckless..
Re: Best method to jig up rear to weld spring pads? [Re: 340SHORTY] #238991
02/28/09 06:32 PM
02/28/09 06:32 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
That's the way I did them on the last car I had leaf springs on.
Re: Best method to jig up rear to weld spring pads? [Re: 340SHORTY] #238992
02/28/09 06:41 PM
02/28/09 06:41 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I am just in the process of doing the same as you, i've also made new front spring hangers.
I have tack welded mine on with a small amount of nose down, i'm going to fit the wheels then drop the car onto the deck check the pinion angle and if it's not right i'll raise it up drop the wheels off, break the tacks, adjust it,weld them solid and put it back together.
What width is yours, mine is 52", so i will need new wheels as my 8-3/4 was stock width, i used c.lines with a 7-1/4 b.s
Mike
Mike
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Best method to jig up rear to weld spring pads? [Re: dc426] #238993
02/28/09 06:58 PM
02/28/09 06:58 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
The second method is what I did after centering it side to side and left the u-bolts just loose enuff to adjust pinion angle then spot welded em then had my buddy full weld em and box em in solid. Now whats wrong w/the sturdy unbreakable 8 3/4?
Re: Best method to jig up rear to weld spring pads? [Re: Thumperdart] #238994
02/28/09 08:35 PM
02/28/09 08:35 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Everyone is correct,Set the car at ride height,center the rearend side to side,set the pinion angle,lock it down with the u-bolts and tack weld the spring pads.Remove the u-bolts and complete the welds.
Re: Best method to jig up rear to weld spring pads? [Re: B G Racing] #238995
02/28/09 09:14 PM
02/28/09 09:14 PM
Tampa Florida
dc426 Offline OP
dc426  Offline OP
Tampa Florida
Thanks guys
Re: Best method to jig up rear to weld spring pads? [Re: dc426] #238996
02/28/09 09:44 PM
02/28/09 09:44 PM
Saskatchewan, Canada
barracudabob Offline
I'll be doing this soon. How much difference is ther in driveshaft length? Thanks, Bob
