Speedmaster SB roller rockers any good?
#2389735
10/19/17 10:48 AM
10/19/17 10:48 AM
Posts: 394 Ohio
moparjoe360.4
Ohio
I'm looking into getting roller rockers for a 410 stroker I'm building, I really want Harland Shaps but can't swing the $700 right now. I found what I think is a good deal on a set of Speedmasters, but it's the first time I've heard of them so I don't know if I should pull the trigger or save the $$$ for a set of Harland Sharps. Another question I have is will I need new push rods with them. I'm on a tight budget and the original plan was to reuse the stock stamped rockers and push rods. I have a .508/ 292 purpleshaft for it already and it's just a street/strip deal. Any advice is greatly appreciated!
Re: Speedmaster SB roller rockers any good?
[Re: moparjoe360.4]
#2389769
10/19/17 12:11 PM
10/19/17 12:11 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Before i bought that stuff i would probably look around for a set of 273 adjustable rockers. Usually can find them easily and cheap.
[Re: B3422W5]
#2390061
10/19/17 10:45 PM
10/19/17 10:45 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
Before i bought that stuff i would probably look around for a set of 273 adjustable rockers. Usually can find them easily and cheap. That's a pretty good idea, what sucks is my dad and I have scrapped multiple sets of those rockers over the years because they got wet in floods. I'm guessing the Speedmasters are cheep import junk from the price point, that's why I asked. I can get my hands on a set complete with hold downs for under $200.
[Re: moparjoe360.4]
#2390200
10/20/17 08:48 AM
10/20/17 08:48 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
Most adjustable rockers use ball and cup pushrods, so yes, you will need new pushrods. At .500" lift, you are not stressing the valvetrain, so those rockers will probably work for now. But as your engine develops, the demands will become higher, and you will be needing different rockers. H/S are so popular, with a little searching, you can find a used set with shafts for the right price.
[image][/image]
[Re: moparjoe360.4]
#2390306
10/20/17 02:51 PM
10/20/17 02:51 PM
fast68plymouth
So. Burlington, Vt.
My default "budget" rockers are the Mancini HS variety. I think they're under $500 for rockers, spacers, shafts.
I'm not in the "Chinese rockers" camp. I'd use the original ones on a 292 cam before I ran $200 offshore stuff.
[Re: fast68plymouth]
#2390379
10/20/17 06:00 PM
10/20/17 06:00 PM
Posts: 394 Ohio
moparjoe360.4
Ohio
I'm not in the "Chinese rockers" camp. I'd use the original ones on a 292 cam before I ran $200 offshore stuff. That's the kind of Info I was looking for. It's the way I've always swayed but the price tempted me this time for some reason.
[Re: Medlock51]
#2390570
10/20/17 11:08 PM
10/20/17 11:08 PM
Porter67
So what brand crank and rods do you use? I shy away from that import stuff... they might look good but often don't perform very good. You get what you pay for...
