Engine Block Inspection Help Needed - Issue or Not? #2388418
10/16/17 10:08 PM
10/16/17 10:08 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
A friend of mine is looking for a 340 engine block and he came across one that had spun a rod. When I looked at the block with him I noticed a couple of chips in the casting. Is this a major issue?
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2388445
10/16/17 11:02 PM
10/16/17 11:02 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
smooth out the rough edges and be ok ,
that crank is in poor condition !
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2388448
10/16/17 11:07 PM
10/16/17 11:07 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
Was the rod loose on the ate up rod bearing and then hit the block there? Does he plan on using the rods that come out of that engine?
How much $$ is this engine?
More to think about.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: NANKET] #2388454
10/16/17 11:15 PM
10/16/17 11:15 PM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
Timing chain was real loose... did not see any major damage to the rods though. I believe he was asking $600 for the block, pistons, rods, water pump. No heads or intake. I figured he would need to replace the crank at a minimum. Appears to be standard bore.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2388509
10/17/17 12:55 AM
10/17/17 12:55 AM
Cab_Burge Online work
Cab_Burge  Online Work
The only way I would buy that block and parts is under the condition that the block be magnafluxed and pressure tested first, it tests oaky buy it. If it doesn't test good forget it down twocents I would try and negotiate that the seller pays for the testing if it tests bad work scope twocents
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2388635
10/17/17 11:04 AM
10/17/17 11:04 AM
an8sec70cuda Offline
The block doesn't concern me. Smooth out the edges like mentioned above and use it.
The crank can probably be turned. The rods may be able to be saved...the one that spun might need replacing.
$600 seems a lil high, but then again, std. bore 340s are hard to find. If it isn't std. bore, I wouldn't shell out 600 for it.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2388637
10/17/17 11:06 AM
10/17/17 11:06 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'm not even sure I'd want to invest the money to test the block. I think I would just pass on it.
That entire engine was whipped to death. Loose timing change, spun rod, even the cam looks like dog crap.
You know at least one rod is bad, may as well buy a new set.
You can be pretty sure that the block needs bored so the pistons are useless.
Odds are real good the water pump is a death to death as the rest of the engine. Replacement is a matter of course.
So only the block is of any potential use and it would not surprise me in the least to find out that cleaning, magnafluxing and pressure testing the block costs about half the asking price.
So, what can you find for $900?
Don't be the exception.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2388738
10/17/17 02:20 PM
10/17/17 02:20 PM
P
Porter67 Offline
Porter67  Offline
P
Id pass as well, seen that too many times, some pan out some end up with a very cracked block down the road.
Thats not a spun rod, its a "Came apart rod" or "Slapped the block rod".
For the $600 thats "good" 340 block money area.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: Porter67] #2388817
10/17/17 04:28 PM
10/17/17 04:28 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Depending on what this is going into I'd just buy a 360 instead. They look the same in the car if we are talking about a hot rod. A restoration would be different circumstances.
I ran across the same thing years ago. Scabbed together 340's that have been full throttled to death their entire life for $500+, or complete standard bore 360's out of a low mile farm brown truck for 1/3 the price.
If you must have it the notch in the block wouldn't bother me. Feather the sharp edges and move on.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: Neil] #2389519
10/18/17 09:24 PM
10/18/17 09:24 PM
dogdays Offline
dogdays  Offline
$600 is just plain too much money for that core. Pistons are worthless, rods are worthless, crank will need to be ground 0.030 to get rid of that ding, although it is a forged crank. But who is building stock stroke 340s these days? Camshaft is worthless, timing set is worthless. What is left is the block. It needs cleaning in the worst way, then grind the dings smooth, then use dye penetrant testing to see if there are any cracks.
The block is worth $200. Everything else he could give back to the seller, they have no value as I mentioned above.
R.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2389526
10/18/17 09:33 PM
10/18/17 09:33 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm in Waterford. I have a nice 340 block +.030". PM if interested.
Doug
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2389528
10/18/17 09:34 PM
10/18/17 09:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I'm in Waterford. I have a nice 340 block +.030". Also pair of bare Ported T/A heads. Pm if interested
Doug
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2389719
10/19/17 09:01 AM
10/19/17 09:01 AM
Harriman NY
71GTX471 Offline
71GTX471  Offline
Harriman NY
That 340 block looks very rough for $600 Id be very skeptical of it if you could get for $200 maybe. While on the topic I have a 73 340 block missing main caps anyone have a set they would like to part with.
Re: Engine Block Inspection Help Needed - Issue or Not? [Re: vinnyd76] #2389757
10/19/17 11:38 AM
10/19/17 11:38 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I don't think the knicks would bother me but a magnaflux test would be a good idea. You're buying a block, the crank is bad, it has at least one bad rod, the cam and timing chain are consumables so them being worn out is normal. I'd offer $450, if he passes walk away.
