Engine Block Inspection Help Needed - Issue or Not?
#2388418
10/16/17 10:08 PM
10/16/17 10:08 PM
Posts: 1,562 Macomb, MI
vinnyd76
Macomb, MI
A friend of mine is looking for a 340 engine block and he came across one that had spun a rod. When I looked at the block with him I noticed a couple of chips in the casting. Is this a major issue?
Re: Engine Block Inspection Help Needed - Issue or Not?
[Re: vinnyd76]
#2388509
10/17/17 12:55 AM
10/17/17 12:55 AM
Posts: 43,112 Bend,OR USA
Cab_Burge
[Re: vinnyd76]
#2388635
10/17/17 11:04 AM
10/17/17 11:04 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
The block doesn't concern me. Smooth out the edges like mentioned above and use it. The crank can probably be turned. The rods may be able to be saved...the one that spun might need replacing. $600 seems a lil high, but then again, std. bore 340s are hard to find. If it isn't std. bore, I wouldn't shell out 600 for it.
[Re: vinnyd76]
#2388637
10/17/17 11:06 AM
10/17/17 11:06 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I'm not even sure I'd want to invest the money to test the block. I think I would just pass on it.
That entire engine was whipped to death. Loose timing change, spun rod, even the cam looks like dog crap.
You know at least one rod is bad, may as well buy a new set.
You can be pretty sure that the block needs bored so the pistons are useless.
Odds are real good the water pump is a death to death as the rest of the engine. Replacement is a matter of course.
So only the block is of any potential use and it would not surprise me in the least to find out that cleaning, magnafluxing and pressure testing the block costs about half the asking price.
So, what can you find for $900?
[Re: Porter67]
#2388817
10/17/17 04:28 PM
10/17/17 04:28 PM
Posts: 20,478 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Depending on what this is going into I'd just buy a 360 instead. They look the same in the car if we are talking about a hot rod. A restoration would be different circumstances.
I ran across the same thing years ago. Scabbed together 340's that have been full throttled to death their entire life for $500+, or complete standard bore 360's out of a low mile farm brown truck for 1/3 the price.
If you must have it the notch in the block wouldn't bother me. Feather the sharp edges and move on.
