Pass compartment battery #2388623
10/17/17 10:53 AM
10/17/17 10:53 AM
Shelby Twp. Mi
HardcoreB Offline OP
Shelby Twp. Mi
I am leaning toward locating a light-weight battery in the passenger-side footwell area. I want a proven battery first for safety reasons. The car has a 88amp 12V alternator which CAN be converted to 16V. Looking for recommendations e.g.-brand/type/size. Also does it seem tech inspection is becoming more accepting of this practice? HELP
Re: Pass compartment battery [Re: HardcoreB] #2388644
10/17/17 11:12 AM
10/17/17 11:12 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Don't think that a battery is acceptable in the drivers compartment.
Re: Pass compartment battery [Re: HardcoreB] #2388769
10/17/17 03:21 PM
10/17/17 03:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rule book says (8.1) Batteries may not be located in driver or passenger compartment.
If I were going to try to get away with it or your tech guys don't care, I would at least put it in a sealed, vented container like Moroso sells and make sure it is properly restrained so it doesn't come lose in the event of an accident.
Re: Pass compartment battery [Re: CMcAllister] #2388780
10/17/17 03:36 PM
10/17/17 03:36 PM
dogdays Offline
dogdays  Offline
The battery should be vented to outside the body. If overcharged the standard lead-acid battery can produce hydrogen with explosive results.
A lithium ion battery contains no water, AFAIK, and cannot produce hydrogen. Now, in certain cases the Li-ion battery itself blows or burns up. Will the NHRA start approving these batteries for in-cab use?
R.
Re: Pass compartment battery [Re: dogdays] #2388794
10/17/17 03:50 PM
10/17/17 03:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, just ask Boeing.
Re: Pass compartment battery [Re: dogdays] #2388925
10/17/17 07:56 PM
10/17/17 07:56 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
R.
I doubt it. Grays about burnt a Pro Stocker to the ground earlier this year because of one.
Re: Pass compartment battery [Re: HardcoreB] #2389022
10/17/17 10:47 PM
10/17/17 10:47 PM
Cochise Co, Az, From Detroit
moetown Offline
moetown  Offline
Somebody posted a thread/info recently that monte smith did about battery/cable related starting issues. I think he had a small lithium battery on passenger side floorboard, maybe in a buick ? Real clean install with short cables.
At the time I was thinking how could it be nhra legal.
Re: Pass compartment battery [Re: HardcoreB] #2389040
10/17/17 11:22 PM
10/17/17 11:22 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
When I was meeting with Jim Bongard, the NHRA Tech inspector for our area to get my cage recertified, I asked him if I could mount a lithium ion battery in the cab. He said no. so I mounted it on the in side frame rail, is close to the starter as I could get it.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Pass compartment battery [Re: Hemi_Joel] #2389234
10/18/17 11:54 AM
10/18/17 11:54 AM
Shelby Twp. Mi
Shelby Twp. Mi
Thank you all for your input. I did further read the current series of THREADS here regarding Lithium batteries and am leaning toward these antigravity AND yes installing it below the floor boards. these appear to be 12v...Joel, could you physically measure LxWxH of your street rod batt please? ALSO someone posted a good LINK in WhteDarts Thread about new developing battery technology...in this they explain the worse cause of lithium battery degradation to be a rapid recharging rate...in the meantime before these 'tolerant' batteries are produced...HOW does a bracket racer with an alternator and pit charger replenish a battery at an acceptable rate?
Re: Pass compartment battery [Re: HardcoreB] #2389283
10/18/17 01:01 PM
10/18/17 01:01 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
I charge my 12 volt Diehard platinum battery at home with a trickle charger MAYBE 1-2 times a month. 60 amp one wire alternator used at all times while racing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Pass compartment battery [Re: HardcoreB] #2389316
10/18/17 02:23 PM
10/18/17 02:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Best thing to do is buy the battery and charger from the manufacturer. Lithium batteries require less voltage to charge at typically .7-1.1 volts less than their lead acid/AGM counterparts. Most all lithium manufactures list the max charge voltage and rate for their batteries. For instance my AGM 16V charger like we use in the Dragster charges at almost 19 volts, my Lithium one maxes out at 18.2
Re: Pass compartment battery [Re: HardcoreB] #2389323
10/18/17 02:53 PM
10/18/17 02:53 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Before alternators came into fashion on race cars, it was common to run 2 batteries to avoid problems in late rounds after a long day. A lot of Stockers still do since they have to run a battery in the stock location anyway,
Re: Pass compartment battery [Re: HardcoreB] #2389425
10/18/17 05:51 PM
10/18/17 05:51 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
What I'm looking at doing is dropping in a very small metal battery box next to the frame rail on the passenger side floor.. with a Zeus fastened cover.. my lithium battery is only about the size of a quart of oil. technically the battery would not be in the passenger compartment.. but it would be accessed through the passenger compartment whistling
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Pass compartment battery [Re: Al_Alguire] #2389441
10/18/17 06:30 PM
10/18/17 06:30 PM
Shelby Twp. Mi
Shelby Twp. Mi
OK so you are NOT using an alternator? I would like to use my alt but there should be a way to regulate the recharging amperage?
Re: Pass compartment battery [Re: WHITEDART] #2389447
10/18/17 06:35 PM
10/18/17 06:35 PM
Shelby Twp. Mi
Shelby Twp. Mi
I measured last night and it appears I have room in the area outside the frame below the floor between the firewall and orig t-bar crossmember...based on what I have READ, if I were you I'd save yourself ANY potential grief and TRY to mount it there. My floor over there is non-factory 'tin'...essentially tube chassis from firewall back.
Re: Pass compartment battery [Re: WHITEDART] #2389450
10/18/17 06:53 PM
10/18/17 06:53 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
When putting this sort of thing in the trunk there is a spec for bulkhead material. When I put the fuel cell in place of the spare tire in my '68
barracuda I wanted to keep the trap door functional so I just made a cover for the cell that attaches to the floor. There's an access door for filling right in the top. Never had a complaint from a tech inspector. When it came time to put the battery in the trunk I just made a cover that's held to the floor with wing nuts. The battery hangs through the floor about half-way so venting isn't an issue. If you cover it in the proper bulkhead material and have the bottom open it should pass tech but I won't guarantee it. Tech inspectors are a crapshoot and usually not technically literate. runaway
