Re: Pass compartment battery
[Re: HardcoreB]
#2388769
10/17/17 03:21 PM
10/17/17 03:21 PM
Posts: 11,578 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Rule book says (8.1) Batteries may not be located in driver or passenger compartment.
If I were going to try to get away with it or your tech guys don't care, I would at least put it in a sealed, vented container like Moroso sells and make sure it is properly restrained so it doesn't come lose in the event of an accident.
[Re: dogdays]
#2388794
10/17/17 03:50 PM
10/17/17 03:50 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Now, in certain cases the Li-ion battery itself blows or burns up. Yeah, just ask Boeing.
[Re: dogdays]
#2388925
10/17/17 07:56 PM
10/17/17 07:56 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
The battery should be vented to outside the body. If overcharged the standard lead-acid battery can produce hydrogen with explosive results.
A lithium ion battery contains no water, AFAIK, and cannot produce hydrogen. Now, in certain cases the Li-ion battery itself blows or burns up. Will the NHRA start approving these batteries for in-cab use?
R. I doubt it. Grays about burnt a Pro Stocker to the ground earlier this year because of one.
[Re: HardcoreB]
#2389040
10/17/17 11:22 PM
10/17/17 11:22 PM
Posts: 7,490 Minnesota
Hemi_Joel
Minnesota
When I was meeting with Jim Bongard, the NHRA Tech inspector for our area to get my cage recertified, I asked him if I could mount a lithium ion battery in the cab. He said no. so I mounted it on the in side frame rail, is close to the starter as I could get it.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: HardcoreB]
#2389283
10/18/17 01:01 PM
10/18/17 01:01 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thank you all for your input. I did further read the current series of THREADS here regarding Lithium batteries and am leaning toward these antigravity AND yes installing it below the floor boards. these appear to be 12v...Joel, could you physically measure LxWxH of your street rod batt please? ALSO someone posted a good LINK in WhteDarts Thread about new developing battery technology...in this they explain the worse cause of lithium battery degradation to be a rapid recharging rate...in the meantime before these 'tolerant' batteries are produced...HOW does a bracket racer with an alternator and pit charger replenish a battery at an acceptable rate? I charge my 12 volt Diehard platinum battery at home with a trickle charger MAYBE 1-2 times a month. 60 amp one wire alternator used at all times while racing.
[Re: HardcoreB]
#2389316
10/18/17 02:23 PM
10/18/17 02:23 PM
Posts: 19,367 Las Vegas
Al_Alguire
Las Vegas
Best thing to do is buy the battery and charger from the manufacturer. Lithium batteries require less voltage to charge at typically .7-1.1 volts less than their lead acid/AGM counterparts. Most all lithium manufactures list the max charge voltage and rate for their batteries. For instance my AGM 16V charger like we use in the Dragster charges at almost 19 volts, my Lithium one maxes out at 18.2
[Re: HardcoreB]
#2389323
10/18/17 02:53 PM
10/18/17 02:53 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Before alternators came into fashion on race cars, it was common to run 2 batteries to avoid problems in late rounds after a long day. A lot of Stockers still do since they have to run a battery in the stock location anyway,
[Re: HardcoreB]
#2389425
10/18/17 05:51 PM
10/18/17 05:51 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
What I'm looking at doing is dropping in a very small metal battery box next to the frame rail on the passenger side floor.. with a Zeus fastened cover.. my lithium battery is only about the size of a quart of oil. technically the battery would not be in the passenger compartment.. but it would be accessed through the passenger compartment
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: Al_Alguire]
#2389441
10/18/17 06:30 PM
10/18/17 06:30 PM
Posts: 4,050 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Best thing to do is buy the battery and charger from the manufacturer. Lithium batteries require less voltage to charge at typically .7-1.1 volts less than their lead acid/AGM counterparts. Most all lithium manufactures list the max charge voltage and rate for their batteries. For instance my AGM 16V charger like we use in the Dragster charges at almost 19 volts, my Lithium one maxes out at 18.2 OK so you are NOT using an alternator? I would like to use my alt but there should be a way to regulate the recharging amperage?
