Z bar and clutch fork problems 70 road runner #2388985
10/17/17 09:26 PM
10/17/17 09:26 PM
NJ, USA
Kevlisa Offline OP
Kevlisa  Offline OP
NJ, USA
I'm having a problem with the Z bar/clutch rod/clutch fork on my 70 road runner. I'm 99% sure the bellhousing, fork, Z bar and clutch rod are the correct parts but I can't get the rod to line up with the fork. Can anybody supply some photos of their setup? I used the lower hole for the ball stub in the bellhousing. The upper hole seems to knock the Z bar out of whack. The lower hole sets the Z bar too low to line up with the fork. Any suggestions or photos are much appreciated.
Re: Z bar and clutch fork problems 70 road runner [Re: Kevlisa] #2389096
10/18/17 01:07 AM
10/18/17 01:07 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Got the z-bar in end for end ?? Straight bracket for the pedal rod, bent bracket for the fork rod.
Re: Z bar and clutch fork problems 70 road runner [Re: Kevlisa] #2389150
10/18/17 06:00 AM
10/18/17 06:00 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Does it all look like this?
Re: Z bar and clutch fork problems 70 road runner [Re: Kevlisa] #2389311
10/18/17 02:08 PM
10/18/17 02:08 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Go to the Brewer site and compare your parts to theirs.
http://www.brewersperformance.com/category10.php
Re: Z bar and clutch fork problems 70 road runner [Re: Kevlisa] #2389395
10/18/17 04:46 PM
10/18/17 04:46 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Without seeing the actual parts, hard to understand the problem...
I have a 70 RR and had an alignment issue with the clutch rod pushing the fork. I took my Z-bar over to our local Mopar guru, who then pulled out (3) different Z-bars all of the same width so they would all mount the same.. The difference was the location of the tab for connecting to the clutch rod. The proper Z-bar had the tab closest to the engine side so then the rod would push straight back to the fork not at an angle...
I have had the RR for 17 years but sometime in its previous life someone had swapped out the Z-bar installing the wrong one.
Just my $0.02... wink
Re: Z bar and clutch fork problems 70 road runner [Re: Sinitro] #2389566
10/18/17 10:38 PM
10/18/17 10:38 PM
NJ, USA
Kevlisa Offline OP
Kevlisa  Offline OP
NJ, USA
Thanks for the input. I think I have it figured out. The bracket that the clutch fork mounts to is in the wrong set of holes. I have to move it. Should fix the problem by lowering the fork. My bellhousing and Z bar are the correct parts.
