Small block stroker guys #2388516
10/17/17 01:01 AM
10/17/17 01:01 AM
Colorado Springs, Colorado
Dartthunder340 Offline OP
A rod decided it had enough and made an exit on my 340 Friday night at the races. Planning my next build and am looking seriously at a Bloomer Performance kit. Thinking if the block can be saved, a 422 would be nice. What rpms are you turning these? I have a set of W2’s (open chamber, race) that will get sent out for porting provided they are okay as well. They can be opened up quite a bit as they are not too far away from stock size ports now (has mild port work). Any suggestions or experiences? Thanks and I’ll definitely have more questions.
Better get inside Ma. Looks like a storm's comin'.
Re: Small block stroker guys [Re: Dartthunder340] #2388525
10/17/17 01:17 AM
10/17/17 01:17 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
When I had a small 520 lift cam in my 408 I shifted at 6400 and ran low 10's. When I put the roller cam in it and my better set of Edelbrock heads I shifted at 6700 and ran 9.60's. When I built my 422 with a solid lift cam and ported 360-1 heads I've gone some high 9.40's shifting at 7000 rpm. Over the Winter I hope to upgrade to a roller cam and possibly a few more cubic inches
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block stroker guys [Re: Dartthunder340] #2388530
10/17/17 01:23 AM
10/17/17 01:23 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
When i had a 408 with ported indy 360-1 and solid roller 268/272 680/700 108 with 11.5:1 compression it made peak power at 6800 so i shifted at 6800.
Re: Small block stroker guys [Re: Dartthunder340] #2388691
10/17/17 12:36 PM
10/17/17 12:36 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Ryan Johnson would be a good guy for you to talk to.
Re: Small block stroker guys [Re: justinp61] #2388693
10/17/17 12:37 PM
10/17/17 12:37 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I agree talk to Ryan , I shift mine at 6500 but I m
On a stop to run mid 11s
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Small block stroker guys [Re: Dartthunder340] #2388935
10/17/17 08:15 PM
10/17/17 08:15 PM
monticello,ms
andy3965 Offline
andy3965  Offline
monticello,ms
Brett Miller would be the guy to talk to, not Ryan!!!!!!
MOPAR BORN,MOPAR BRED,AND WHEN I DIE I'LL BE MOPAR DEAD!!!
Re: Small block stroker guys [Re: andy3965] #2388939
10/17/17 08:28 PM
10/17/17 08:28 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Ryan is more than capable on any Mopar smallblock heads. Its what he does full time for a living. And has for a long time
Made my W5's fly, and a local guy who does very good work was extremely impressed by the work Ryan did on my brothers eddie heads after carefully looking them over.
Not sure where you get off bashing Ryan, Probably not a better resource in the country.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small block stroker guys [Re: Dartthunder340] #2388997
10/17/17 09:41 PM
10/17/17 09:41 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I shift my W2 headed 408 at 7100. It made peak power around 6800 but 7100 is where it seems happiest in the car. The cam and compression specs are similar to what Mopar Dave listed above. Here’s the Dyno sheet:
Re: Small block stroker guys [Re: Dartthunder340] #2389000
10/17/17 09:47 PM
10/17/17 09:47 PM
bronx n.y
O
one bad fish Offline
O
bronx n.y
Both of those guys r great engine builders you won’t go wrong with either one
Re: Small block stroker guys [Re: one bad fish] #2389571
10/18/17 10:45 PM
10/18/17 10:45 PM
Mi.
G-Money1320 Offline
G-Money1320  Offline
Mi.
Maybe I need to spin my 416 a little higher since I only shift at 5900 and usually it goes to 6300 through the traps!
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out.
11.06 open headers----so far!!
Re: Small block stroker guys [Re: Dartthunder340] #2390774
10/21/17 12:33 PM
10/21/17 12:33 PM
Can I please get experiences or advice on a 4.125” in a 340 factory block? Been reading a little on the oiling and cooling mods. I realize an R3 would be the way to go, just trying to utilize what I already have. Thanks again.
