G3 Hemi New Best
#2388110
10/16/17 12:43 PM
10/16/17 12:43 PM
Triple Threat
Renton Washington
Well this season is officially in the books after yesterday. 194 runs on the year, won a number of events, 2 Wallys, the Super Street Championship at my local track and had a fun time meeting new people and going to new events.
To top the year off the car ran a new best yesterday in testing. incrementals: 1.374 60 foot 6.17 @ 111.08 mph 9.74 @ 136.90 mph Only change from my normal bracket set up was tossing on a set of 325/50/15 drag radials. 2 inches less height and radial construction was worth quite a bit. The car still wants more gear, it likes shifting around 7300+ but is only going through the traps around 6900. I think there is probably another tenth available swapping from 4.10's to 4.30's or 4.56's but with a Dana, that's not a easy task.
Car is 3380# with me in the seat and has over 400 runs on it in the past 2 seasons with the only maintenance being oil changes.
Very happy with how this little engine is running. Time to freshen it up and get ready for 2018.
Re: G3 Hemi New Best
[Re: Triple Threat]
#2388119
10/16/17 12:55 PM
10/16/17 12:55 PM
Posts: 13,492 Marion, South Carolina [><]
an8sec70cuda
That's awesome Dustin! One heck of a season!
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: Dave Hall]
#2388249
10/16/17 04:55 PM
10/16/17 04:55 PM
Triple Threat
Renton Washington
Good job in that mineshaft air! Hey man! What are you doing to freshen your engine? It will depend on what I find when we pull it apart. At the moment planning for a generic rebuild; Rings, Bearings and lifters. Will of course check valve springs and other common failure points while we are there, not sure whats going to need replaced honestly as this is uncharted territory for the G3. Springs are Beehives with a Max life treatment so they might be perfectly fine. Lifters might be fine as well but i'll change them for piece of mind.
[Re: gregsdart]
#2388293
10/16/17 06:40 PM
10/16/17 06:40 PM
Triple Threat
Renton Washington
Congratulations on a heck of a season, and new best!! Think the car will tolerate more starting line ratio? Obviously, you have this car DIALED IN!! 95% of the time it probably could. I've never felt the need to chase it however and risk losing consistency on those hot summer days. Also the car on 29.5x10.W's already hovers in the 9.95-10.05 range, and is only legal to 10.0.
[Re: KOS]
#2388294
10/16/17 06:43 PM
10/16/17 06:43 PM
Triple Threat
Renton Washington
NICE !! I know its probably been posted but lets here more about this gen III 2004 5.7 .010 over bore ARP Main and Head Studs 4.050 SCAT Crank Scat H beam rods Custom JE pistons, 15cc Dome, 13.5:1 Cometic head gaskets Apache heads with some porting by Sixpackgut Custom Camshaft 258/264@.050, .620/.630 Ritter intake, Dominator Flange, short version - home port job Stock lifters and valvetrain E85 1050 Dominator by AJ Casini MSD 6 hemi with the 06+ style coils to fire it. 727, 8" continental converter 5700 stall 4.10 rear gear
[Re: Triple Threat]
#2388310
10/16/17 07:17 PM
10/16/17 07:17 PM
Posts: 20,272 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Nice to see the G3's gaining some ground. It keeps us lowly old school small block guys pushing harder. Lol. A good Friend just picked up .20 going to a radial so I see those in my future plans next time I need tires. Now we need to search out some of that good minus sea level air.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
[Re: Triple Threat]
#2388567
10/17/17 03:48 AM
10/17/17 03:48 AM
Posts: 740 WA
JD Dart
WA
Did you do your new best a PR? Nice numbers
best so far 8.53 @ 158.59 MPH 60'1.240
