cal trac shocks or strange #2387894
10/15/17 10:28 PM
10/15/17 10:28 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
anyone try the strange shocks S5282 same length both compressed and extended as the caltracs shocks. caltracs are 9 way strange 10 way. about 20 dollars more for strange. anyone try them
Re: cal trac shocks or strange [Re: plycuda] #2387954
10/16/17 12:28 AM
10/16/17 12:28 AM
Washington
madscientist Offline
Washington
Don't know that strange part number but if they aren't double adjustable find something else.
Re: cal trac shocks or strange [Re: madscientist] #2387967
10/16/17 01:01 AM
10/16/17 01:01 AM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
The caltrack shocks aren't double adjustable but alot of people run them. The strange shock is a bolt in single adjustable just like the caltrac shock. I was wondering if anyone has tried them.
Re: cal trac shocks or strange [Re: plycuda] #2388000
10/16/17 02:36 AM
10/16/17 02:36 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
FWIW I've been 1.33 60 ft. foot brakin and 6.15 @ 109 to the 1/8th slightly lifting and 111.78 all out so far w/old 5-ways in the rear and 90-10's up front..........John does/has suggested that mid 9 and quicker cars COULD benefit from double adjustable s but some still fly on the Ranchos.......... beer
Re: cal trac shocks or strange [Re: Thumperdart] #2388027
10/16/17 07:54 AM
10/16/17 07:54 AM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Like Thumper said....upper to mid 9's probably no issue with the Rancho's. I have been 1.35 at 9.90 with the 5-way adjustable Rancho's. I do have doubles on the front though. And that is where I was able to get the most out of them.
Re: cal trac shocks or strange [Re: Dragula] #2388031
10/16/17 08:57 AM
10/16/17 08:57 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Money is never wasted on better shocks.
Re: cal trac shocks or strange [Re: plycuda] #2388036
10/16/17 09:40 AM
10/16/17 09:40 AM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
The problem with the strange shock is you can not adjust it tight enough to control the cal tracs. even though they are both single adjustable the valving on the rancho is better
JAKES AUTOMOTIVE
Re: cal trac shocks or strange [Re: JAKE68] #2388100
10/16/17 12:29 PM
10/16/17 12:29 PM
long time lurker, short time p...
P
PorkyPig Offline
PorkyPig  Offline
P
Because it's repurposing a 4x4 TRUCK shock. I'm another one with the old 5-way Ranchos and they work Ok, but I'd like to try a DA shock.
Re: cal trac shocks or strange [Re: plycuda] #2388107
10/16/17 12:35 PM
10/16/17 12:35 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
What suspension system are you applying these shocks to?, and what level of performance is the car aimed at?
Re: cal trac shocks or strange [Re: plycuda] #2388108
10/16/17 12:35 PM
10/16/17 12:35 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Check out the vikings!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: cal trac shocks or strange [Re: plycuda] #2388167
10/16/17 02:18 PM
10/16/17 02:18 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I had a Rancho 9 way go bad on my car, pretty much turned into a solid rod. But I also found a bad CE 3 way on the front was bad too, both on the passengers side. I replaced them all with Vikings.
If anyone needs an A body length front or rear shock for a spare drop me a PM.
Re: cal trac shocks or strange [Re: plycuda] #2388187
10/16/17 02:56 PM
10/16/17 02:56 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Strange, AFCO and most others are able to revalve the shocks to a specific application. Most off the shelf shocks are too soft for any serious effort. Strange are OK for a lot of guys if the are calibrated right. We've had pretty good luck with the AFCO Big Gun valving. Not many cars I've been involved with still using out of the box valving.
Re: cal trac shocks or strange [Re: CMcAllister] #2388327
10/16/17 07:45 PM
10/16/17 07:45 PM
Fredericksburg Va
P
plycuda Offline OP
plycuda  Offline OP
P
Fredericksburg Va
I have another race car. This is going to be mainly just going to be on the street. Its a 69 satellite with super stock springs, mini tubed 16.50 x31 quick time pros. I might make a few passes but I'm not putting a cage in it. just want a decent shock don't need anything spectacular. I just saw the strange shocks they sold are bolt in. should run low 11's high 10's unless I hit it with some juice.
Re: cal trac shocks or strange [Re: plycuda] #2388346
10/16/17 08:06 PM
10/16/17 08:06 PM
Washington
Washington
You can get Viking DA's for a reasonable price. Even for what you are doing, skimping on shocks just doesn't make sense to me.
My street car runs low 12's and I have Viking DA's on all 4 corners. I'd spend that money all over again.
