Page 5 of 6 1 2 3 4 5 6
Re: Best PCV valve? [Re: UCUDANT] #2387204
10/14/17 03:38 AM
10/14/17 03:38 AM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Originally Posted By UCUDANT
Finding the grommet is fun smile The PCV is 3/4 where it enters the valve cover. I ordered (am awaiting) a grommet online that is 3/4" ID, and 1" OD. Since I have aluminum valve covers Iliked this one as it appears deeper and I will trim the lower neck if I need to.
http://www.ebay.com/itm/Ford-Mustang-PCV...2-/111669199849
This grommet is 1.22 OD flame
Re: Best PCV valve? [Re: UCUDANT] #2387274
10/14/17 11:38 AM
10/14/17 11:38 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Nuts.
There's gotta be an industrial application for these grommets. No way the VC makers are molding their own.
Re: Best PCV valve? [Re: A990] #2387493
10/14/17 10:19 PM
10/14/17 10:19 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well I got my valve today now it's off to Summit tomorrow to get the correct Moroso grommet and a spacer with a nipple on it.
I was thinking about just changing to a differn't base plate on my carb but I'm not sure if they all are designed for 4-corner idle circuits. I will need to go with a 3" element if I go with a spacer but then my engine might like the spacer and I could get better throttle response shruggy work
Quick Fuel makes a nice factory type cast replacement with all the ports I need that I might try but I'm not sure how to identify that it will have 4-corner capability.
Help confused
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: UCUDANT] #2387543
10/14/17 11:41 PM
10/14/17 11:41 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Received my two today also, now, if anyone has used a grommet that works for these valves with the MOPAR cast cover please give me a lead...Thanks, Joe
Re: Best PCV valve? [Re: fourgearsavoy] #2387546
10/14/17 11:54 PM
10/14/17 11:54 PM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
You can use the quick fuel base plate for 4 corner idle, just drill the idle feed holes in the rear the same size as what you have on the carb now, they are the round holes below the throttle blades. Check ebay, vendors there offer that baseplate in 2 and 4 corner idle.
Re: Best PCV valve? [Re: 4406bbl] #2387568
10/15/17 01:15 AM
10/15/17 01:15 AM
Rittman Ohio
Rittman Ohio
Thanks for the tech info I'm going to Summit tomorrow and pick one up and see if it will work for me. I'll just make sure all the passages are the same as the Quick Fuel base on my carb now.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: jlatessa] #2387569
10/15/17 01:18 AM
10/15/17 01:18 AM
Rittman Ohio
Rittman Ohio
I don't have any of those valve covers around anymore but I'm gonna pick up one of those Moroso grommets that AndyF posted up.
I'm running the no name Summit valve covers on my 493.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: fourgearsavoy] #2387678
10/15/17 12:03 PM
10/15/17 12:03 PM
moparx Offline
moparx  Offline
received my two yesterday as well. i don't have any particular valve covers in mind yet, so i will decide on a grommet at the appropriate time. however, i really think i'll incorporate an oil mist separator in my application[s].
beer
Re: Best PCV valve? [Re: cudaman1969] #2387732
10/15/17 01:51 PM
10/15/17 01:51 PM
jersey
Spaceman Spiff Offline
jersey
Originally Posted By cudaman1969
Duh, the cheapest and easiest way is to plug it. It's just an emission thing anyway. How many on here have a pcv on there race car?
How many street cars have vacuum pumps tied into the exhaust....
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Best PCV valve? [Re: moparx] #2387865
10/15/17 09:15 PM
10/15/17 09:15 PM
Rittman Ohio
Rittman Ohio
Well I installed the spacer under my carb and pulled the valve cover and pulled the baffle that was too close to the valve cover.
I used the Moroso grommet that AndyF posted about and it works perfectly with the Summit plain Jane tall aluminum valve covers. I was surprised that my 493 is pulling about 13-15" of vacuum as I have never measured it before. I tried to follow the instructions when I set it up but I haven't driven it yet but my idle quality seems smoother. I'm probably going to have to jet up a little because of the spacer but we'll see after I put some miles on it.
So far I'm happy just to have a PCV on the car although I never had any oil mist around my breathers before and my engine is sealed up pretty tight.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: fourgearsavoy] #2388219
10/16/17 03:52 PM
10/16/17 03:52 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Did you guys get a tracking # for the Group Buy PCVs? Mine hasn't shown up as of this AM. Thanks, Steve
Re: Best PCV valve? [Re: UCUDANT] #2388241
10/16/17 04:41 PM
10/16/17 04:41 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Did not get a tracking #, they just showed up Sat., USPS.
Joe
PS , their phone # is 570-899-4544
Re: Best PCV valve? [Re: jlatessa] #2388261
10/16/17 05:17 PM
10/16/17 05:17 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
NAPA 6301075 works. It is a little thicker so the PCV hangs only 1/16" or so below the grommet inside the rocker box.
Re: Best PCV valve? [Re: Skeptic] #2388315
10/16/17 07:27 PM
10/16/17 07:27 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I'm still waiting for mine also.
Re: Best PCV valve? [Re: srunge55] #2388417
10/16/17 10:03 PM
10/16/17 10:03 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Thanks for the feedback. If it doesn't show up in the next couple of days, I'll get in touch with them. wave
Re: Best PCV valve? [Re: UCUDANT] #2388458
10/16/17 11:19 PM
10/16/17 11:19 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
Mine was waiting for me when I got home from work today.
Re: Best PCV valve? [Re: BcudaChris] #2389061
10/17/17 11:58 PM
10/17/17 11:58 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Napa shows that one specs at:
PCV Valve Grommet I.D. 0.7 in.
PCV Valve Grommet O.D. 1.501 in.
PCV Valve Grommet Thickness 0.705 in.
So it's larger than the 1.22" shruggy My Cal custom has a 1" hole. I might have to have it machined open a little?
Looking at the profile shot of this grommet on the Napa site I will just grab one on the way home tomorrow to measure/check https://www.napaonline.com/en/p/NDP6301075
Re: Best PCV valve? [Re: UCUDANT] #2389220
10/18/17 11:39 AM
10/18/17 11:39 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Mine showed up in yesterdays mail. Those folks seem to be on things.
Re: Best PCV valve? [Re: UCUDANT] #2389596
10/18/17 11:12 PM
10/18/17 11:12 PM
New Mexico
UCUDANT Offline OP
Troll Hunter
UCUDANT  Offline OP
Troll Hunter
New Mexico
Ahhhhh thats better, grommet solution at least for now. Cal Custom Valve cover 1" hole, and a 3/4" PCV
(I know a 2006 Chevy 3500 6.6 Duramax trans dip stick tube grommet probably specs real close to what I needed too as I was under one today with a digital caliper laugh2 )
Re: Best PCV valve? [Re: UCUDANT] #2389627
10/19/17 12:13 AM
10/19/17 12:13 AM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I'm glad you got it figured out.
