Page 1 of 3 1 2 3
Swapping to drag radials today, test tonight #2386921
10/13/17 04:21 PM
10/13/17 04:21 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Curious to see if the car likes them.
Taking off 28 11.5 QTP's, installing Hoosier 275 drag radials
Hoping the car " feels" like it has a touch more gear with no growth
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2386933
10/13/17 04:47 PM
10/13/17 04:47 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Do a much shorter burnout with them. large burnouts are not needed. Good luck.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2386935
10/13/17 04:48 PM
10/13/17 04:48 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Quick question too. Have QA1 singles on the back( coilovers with ladderbar suspension)
Would it make sense to loosen the shocks up a couple of clicks wifh the radials?
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2386992
10/13/17 06:12 PM
10/13/17 06:12 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
Maybe. But after you make that first lap with no changes other than the tires. Otherwise you won't know what did what.
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387004
10/13/17 06:47 PM
10/13/17 06:47 PM
Smyrna, South Carolina
STEFF Offline
STEFF  Offline
Yeah, its not that simple. You need to figure out what it likes. Like mentioned above, make a couple base line passes to start, then make one change at a time to see if it liked it. Try it a couple clicks looser than your baseline setting, see what it does. If better, keep loosening until it falls off. Then go tighter a couple clicks at a time till it falls off. Hopefully you get good track prep for the Drag Radials.
Re: Swapping to drag radials today, test tonight [Re: STEFF] #2387052
10/13/17 09:06 PM
10/13/17 09:06 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I made the same switch a few months ago, I like them I can run more pressure and its more stable top end. I ran tubes in my Q.T.P.s I am not with the drag radials. My 60 fts got a little better ( low 1.50s) but I did a gear swap at they same time ( 4.10s to 4.30s) so I don`t know which helped lower the 60 ft. Good Luck with them!
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387091
10/13/17 10:12 PM
10/13/17 10:12 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Still at the track. Going to make one more hit and call it a season
New best each pass
11.40, 11.38, 11.36
All three with a 1.61 60 foot. Previous best 1.62.
Can't wait to get the right converter in this car, doggy out of the gate.
I am convinced this thing will dip into the 10's with swapping to a 904, fresh air hood, and having the converter right, its WAY off
While car was on lift I loosened shocks two clicks. Haven't touched it since
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387122
10/13/17 11:13 PM
10/13/17 11:13 PM
cudadoug Offline
cudadoug  Offline
11.40, 11.38, 11.36
Love it!
Great job with a cool car. We'll take more pics of that car when you have a chance. Hint, hint...
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387124
10/13/17 11:17 PM
10/13/17 11:17 PM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Still here.
Car just surprised me.......... air getting good
11.26@ 118.40 with a 1.58 60 foot.... yee friggin ha.
Now my brother is making me back that pass up. So waiting in line for 5th and final pass.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387146
10/14/17 12:12 AM
10/14/17 12:12 AM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
That's getting it, made my switch to radials a few weeks ago and I will never go back .. good luck and keep after it 👍🏻
Re: Swapping to drag radials today, test tonight [Re: 70dusterjohn] #2387160
10/14/17 12:49 AM
10/14/17 12:49 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Wow that last pass you really picked up. Nice going and good luck on the last pass. up Ron
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387174
10/14/17 01:41 AM
10/14/17 01:41 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Fell of a little on the last pass. Couldnt equal the 26
Here is the slip on my best pass..... best so far in this car
RT....0589
60.....1.5861
330....4.5915
1/8.....7.1503
1/8 mph....95.54
1000... 9.3741
1000 mph..109.4
1320.....11.2690
Mph..........118.48
There is nothing it doesnt like with radials. No bias tires for me ever again
Really pretty tickled, she is headed on the path to 10's i hope. After many years, i am surprised to find myself getting the itch again. Keeps me breathing. I thought i might be gettin to old to really dig this again...... but must be i aint.... lol... lol......
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387198
10/14/17 03:14 AM
10/14/17 03:14 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Awesome! You've got that thing flying. drive
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387211
10/14/17 04:08 AM
10/14/17 04:08 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
RT....0589
60.....1.5861
330....4.5915
1/8.....7.1503
1/8 mph....95.54
1000... 9.3741
1000 mph..109.4
1320.....11.2690
Mph..........118.48
That's pretty f'n cool! up
Re: Swapping to drag radials today, test tonight [Re: Dave Hall] #2387216
10/14/17 04:43 AM
10/14/17 04:43 AM
CA.
RAY1969CARS Offline
RAY1969CARS  Offline
CA.
Where are you at What strip
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387219
10/14/17 05:01 AM
10/14/17 05:01 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Nice effort
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387239
10/14/17 09:39 AM
10/14/17 09:39 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Nice runs.
I have been running drag radials for a few years now. Last year I broke my 3.91 gears and swapped in some 4.56s and a friend gave me some 28" Bias Ply Slicks to use because I needed the extra height. It felt weird going back to that little bit of sway down track. The car went a 1.58 60ft on the bias ply and over the winter I changed over to a 28x10.5 Pro Bracket Radial, first pass was a 1.52 60ft. Like everyone has said though they do get unpredictable when track conditions go away.
68 Barracuda Formula S 340
Re: Swapping to drag radials today, test tonight [Re: RAY1969CARS] #2387249
10/14/17 10:26 AM
10/14/17 10:26 AM
Portage,michigan
B3422W5 Offline OP
B3422W5  Offline OP
Portage,michigan
Michigan. US131 Motorsports Park
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387258
10/14/17 11:06 AM
10/14/17 11:06 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
As long as the track(s) where you go prep reasonably well, you're good. The ones that don't will bring out a radial's evil twin,, "Slippy".
Re: Swapping to drag radials today, test tonight [Re: B3422W5] #2387262
10/14/17 11:16 AM
10/14/17 11:16 AM
Deerfield, Ohio
Deerfield, Ohio
Call M/T ... The reason the radial PRO was design was for marginal tracks ... they took the feed back from the racers and designed a tire that just flat out works if you go to a track that is just not prepped at all yes you will have a problem.
Page 1 of 3 1 2 3
