Swapping to drag radials today, test tonight
#2386921
10/13/17 04:21 PM
10/13/17 04:21 PM
Posts: 11,709 Portage,michigan
B3422W5
Portage,michigan
Curious to see if the car likes them. Taking off 28 11.5 QTP's, installing Hoosier 275 drag radials
Hoping the car " feels" like it has a touch more gear with no growth
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
Re: Swapping to drag radials today, test tonight
[Re: B3422W5]
#2386933
10/13/17 04:47 PM
10/13/17 04:47 PM
Posts: 4,564 Motor City
6PKRTSE
Motor City
Do a much shorter burnout with them. large burnouts are not needed. Good luck.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: B3422W5]
#2386935
10/13/17 04:48 PM
10/13/17 04:48 PM
B3422W5
Portage,michigan
Quick question too. Have QA1 singles on the back( coilovers with ladderbar suspension) Would it make sense to loosen the shocks up a couple of clicks wifh the radials?
[Re: B3422W5]
#2386992
10/13/17 06:12 PM
10/13/17 06:12 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Quick question too. Have QA1 singles on the back( coilovers with ladderbar suspension) Would it make sense to loosen the shocks up a couple of clicks wifh the radials? Maybe. But after you make that first lap with no changes other than the tires. Otherwise you won't know what did what.
[Re: B3422W5]
#2387004
10/13/17 06:47 PM
10/13/17 06:47 PM
Posts: 3,871 Smyrna, South Carolina
STEFF
Yeah, its not that simple. You need to figure out what it likes. Like mentioned above, make a couple base line passes to start, then make one change at a time to see if it liked it. Try it a couple clicks looser than your baseline setting, see what it does. If better, keep loosening until it falls off. Then go tighter a couple clicks at a time till it falls off. Hopefully you get good track prep for the Drag Radials.
[Re: STEFF]
#2387052
10/13/17 09:06 PM
10/13/17 09:06 PM
Posts: 4,975 new jersey usa
11secdart
new jersey usa
I made the same switch a few months ago, I like them I can run more pressure and its more stable top end. I ran tubes in my Q.T.P.s I am not with the drag radials. My 60 fts got a little better ( low 1.50s) but I did a gear swap at they same time ( 4.10s to 4.30s) so I don`t know which helped lower the 60 ft. Good Luck with them!
[Re: B3422W5]
#2387091
10/13/17 10:12 PM
10/13/17 10:12 PM
B3422W5
Portage,michigan
Still at the track. Going to make one more hit and call it a season New best each pass 11.40, 11.38, 11.36 All three with a 1.61 60 foot. Previous best 1.62. Can't wait to get the right converter in this car, doggy out of the gate. I am convinced this thing will dip into the 10's with swapping to a 904, fresh air hood, and having the converter right, its WAY off While car was on lift I loosened shocks two clicks. Haven't touched it since
[Re: B3422W5]
#2387124
10/13/17 11:17 PM
10/13/17 11:17 PM
B3422W5
Portage,michigan
Still here. Car just surprised me.......... air getting good 11.26@ 118.40 with a 1.58 60 foot.... yee friggin ha. Now my brother is making me back that pass up. So waiting in line for 5th and final pass.
[Re: B3422W5]
#2387174
10/14/17 01:41 AM
10/14/17 01:41 AM
B3422W5
Portage,michigan
Fell of a little on the last pass. Couldnt equal the 26 Here is the slip on my best pass..... best so far in this car
RT....0589 60.....1.5861 330....4.5915 1/8.....7.1503 1/8 mph....95.54 1000... 9.3741 1000 mph..109.4
1320.....11.2690 Mph..........118.48 There is nothing it doesnt like with radials. No bias tires for me ever again Really pretty tickled, she is headed on the path to 10's i hope. After many years, i am surprised to find myself getting the itch again. Keeps me breathing. I thought i might be gettin to old to really dig this again...... but must be i aint.... lol... lol......
[Re: B3422W5]
#2387239
10/14/17 09:39 AM
10/14/17 09:39 AM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
Nice runs.
I have been running drag radials for a few years now. Last year I broke my 3.91 gears and swapped in some 4.56s and a friend gave me some 28" Bias Ply Slicks to use because I needed the extra height. It felt weird going back to that little bit of sway down track. The car went a 1.58 60ft on the bias ply and over the winter I changed over to a 28x10.5 Pro Bracket Radial, first pass was a 1.52 60ft. Like everyone has said though they do get unpredictable when track conditions go away.
68 Barracuda Formula S 340
[Re: RAY1969CARS]
#2387249
10/14/17 10:26 AM
10/14/17 10:26 AM
B3422W5
Portage,michigan
Where are you at What strip
Michigan. US131 Motorsports Park
[Re: B3422W5]
#2387258
10/14/17 11:06 AM
10/14/17 11:06 AM
BradH
As long as the track(s) where you go prep reasonably well, you're good. The ones that don't will bring out a radial's evil twin,, "Slippy".
