Guesses on E.T and M.P.H 426 hemi #2386977
10/13/17 05:43 PM
10/13/17 05:43 PM
MI
MI Mopar Works Offline OP
MI
I'd like to hear what you guys think this combo should run
3900 lb 1969 B body
426 Hemi stocker with 11.5:1 C.R
Stockish solid flat tappet cam
Full exahust with iron manifolds
Stock 727 trans with 11 inch 2800 stall converter
8 3/4 4:30 gear
Racing on seasoned redline bias ply tires
Engine makes roughly 600 HP and 500 lb ft
Now, imagine the car is dialed in, but 60 ft's are bad due to peddling the tires.
Go....
MI Mopar Works (734)624-2212
Parts Sales
Restoration and detailing of all kinds of mopar hardware
https://www.facebook.com/MIMoparWorks/
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2386984
10/13/17 05:56 PM
10/13/17 05:56 PM
N.E. Ohio
6bblFLASH Offline
6bblFLASH  Offline
N.E. Ohio
12.47
70` Cuda`,440 6BBL Jerico,Dana 4.56 Still on 93 Pump Gas
9.87 @ 136/1.31-60ft.`09 Mopar Nationals PASSON PERFORMANCE "Stick-Shift" Champ!
2013 StickShift Challenge Winner@ Mopar Nationals!
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387001
10/13/17 06:35 PM
10/13/17 06:35 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
12.70 @ 115
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387005
10/13/17 06:51 PM
10/13/17 06:51 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
12.32 @ 119
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387013
10/13/17 07:18 PM
10/13/17 07:18 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
12.85 108mph
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387022
10/13/17 07:39 PM
10/13/17 07:39 PM
13.00+ ET and 115+ MPH if you can get it to leave halfway decent twocents
The seasoned bias ply tires being the limiters shruggy
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387054
10/13/17 09:11 PM
10/13/17 09:11 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
That's very similar to the combo I had in my 67 GTX back in '01-03. Started out in the low 13's, eventually got it down to 11.80's - 12.30's depending on air density and traction. That was probably about 100 passes with no major changes in power, but tweaking lots of little things and getting the driving down. F70 14 bias plys. .
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387077
10/13/17 09:44 PM
10/13/17 09:44 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
About the same combo as Dudeks Hemi Super Bee clone........ And that went 10's..... Sooooooo........
Re: Guesses on E.T and M.P.H 426 hemi [Re: fast68plymouth] #2387084
10/13/17 09:59 PM
10/13/17 09:59 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
About the same, within 250 horse or so.... up
Edit: oh you meant the pure stock car, not the FAST car. Whoops. blush
Re: Guesses on E.T and M.P.H 426 hemi [Re: Hemi_Joel] #2387090
10/13/17 10:07 PM
10/13/17 10:07 PM
NEW JERSEY
dynamite Offline
dynamite  Offline
NEW JERSEY
Mid 12"s , @ 108 with those tires,, good slicks maybe 11.90's @114mph
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387116
10/13/17 11:01 PM
10/13/17 11:01 PM
UK
rb446 Offline
rb446  Offline
UK
@580hp 11.00@122 with hook>>>12.2's@120 with peddle
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Guesses on E.T and M.P.H 426 hemi [Re: rb446] #2387126
10/13/17 11:21 PM
10/13/17 11:21 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
3900 lbs, is that with driver?
If so,
123 MPH
11.65 due to peddling
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387136
10/13/17 11:43 PM
10/13/17 11:43 PM
Az
Crizila Offline
Crizila  Offline
Az
12.80
Fastest 300
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387180
10/14/17 01:55 AM
10/14/17 01:55 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
11.90’s
Re: Guesses on E.T and M.P.H 426 hemi [Re: WO23Coronet] #2387319
10/14/17 01:12 PM
10/14/17 01:12 PM
N.Y.
sixpacksteve Offline
N.Y.
when do we get the results?
Hell Hath No Fury Like Mine
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387324
10/14/17 01:28 PM
10/14/17 01:28 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
12.75@ 116
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387329
10/14/17 01:43 PM
10/14/17 01:43 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Where does the 600 hp come from?
Boffin Emeritus
Re: Guesses on E.T and M.P.H 426 hemi [Re: polyspheric] #2387374
10/14/17 03:43 PM
10/14/17 03:43 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Agree. Doesnt sound remotely like 600.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Guesses on E.T and M.P.H 426 hemi [Re: B3422W5] #2387383
10/14/17 04:13 PM
10/14/17 04:13 PM
U
Uncle Barry Offline
Uncle Barry  Offline
U
I thought the same when he described his combo shruggy ... That's why I gave it a 12.70 but padded the mph a lil bit just in case laugh2
Re: Guesses on E.T and M.P.H 426 hemi [Re: MI Mopar Works] #2387384
10/14/17 04:16 PM
10/14/17 04:16 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
13.20 @ 105
