Double Cardan Joint rebuild, #2384930
10/10/17 06:45 AM
10/10/17 06:45 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Front shaft on my 01 Ram, needs joint rebuilt.
Seen a couple of vids on you tube, doesn't look too terrible.
anyone try to do it?
Good results? Problems?
Re: Double Cardan Joint rebuild, [Re: sthemi] #2385049
10/10/17 12:50 PM
10/10/17 12:50 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
The one time I did it years ago, IIRC by the time you got all the parts bought and then actually did the replacement, for a few bucks more a reman unit was the better choice. As an alternative some driveline shops can replace just the joint by cutting them out and welding in a new joint.
Re: Double Cardan Joint rebuild, [Re: sthemi] #2385322
10/10/17 10:33 PM
10/10/17 10:33 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I agree with 6pack.we did like 2 at the shop.Then it was cheaper to use a drive shaft shop.Lots of GM used them as did Imperials on the rears.DS shop just changed them to a slip joint.We had 2 that went bad after rebuildig the OE joints.The guy that did them did a bunch when he was at Gm and said it was a crap shoot rebuilding them.Rocky
Chrysler Firepower
Re: Double Cardan Joint rebuild, [Re: sthemi] #2385323
10/10/17 10:36 PM
10/10/17 10:36 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
most of the time you get them split and find damage that only a driveline shop is equipped to handle. We do new/reman units.
Re: Double Cardan Joint rebuild, [Re: J_BODY] #2385465
10/11/17 07:26 AM
10/11/17 07:26 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks for the replies, leaning toward having the shop do it.
Re: Double Cardan Joint rebuild, [Re: sthemi] #2385468
10/11/17 07:49 AM
10/11/17 07:49 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
My experience is quite different I've redone a bunch and they hold up fine.
Note most of the ones I've done have been Spicer. A couple have been Saginaw type which is likely what you have. You'll need a torch for disassemble, they use injected plastic to hold the cups in. Melt the plastic (stinks like hell) then basically a regular u joint rnr.
If the centering ball and spring are ok, you're good.
Angry white pureblood male
Re: Double Cardan Joint rebuild, [Re: ruderunner] #2386114
10/12/17 06:27 AM
10/12/17 06:27 AM
Chicago Burbs
sthemi Offline OP
sthemi  Offline OP
Chicago Burbs
Thanks Ruderunner,
I just ordered a low miles shaft from a JY in Kentucky, hopefully it will drop in and work. Not real expensive.
