roots blower for small block? 144, 174, 177 b&m weiand #238488
02/27/09 11:16 PM
02/27/09 11:16 PM
Clinton Twp. Michigan
coronet1966d Offline OP
i see you can get a kit through jegs for a small chevy for $1900 but after a while searching the web no results for a small block chrysler i see that dick landy industries did offer a kit but is now no longer in business id really like to pursue this type of build because it would be very different any advice?
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: coronet1966d] #238489
02/27/09 11:21 PM
02/27/09 11:21 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
see if BDS blowerdriveservice has them in stock.$$
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: blownzoom440] #238490
02/27/09 11:30 PM
02/27/09 11:30 PM
all BDS lists are the 671 type blowers, the huge stuff for around $4000 im looking for something more along the lines of this
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: coronet1966d] #238491
02/27/09 11:43 PM
02/27/09 11:43 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: Dragula] #238492
02/27/09 11:48 PM
02/27/09 11:48 PM
Dragula Offline
Dragula  Offline
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: Dragula] #238493
02/28/09 12:12 AM
02/28/09 12:12 AM
YES! thats it where do i send my money!?
that setup just looks amazing
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: coronet1966d] #238494
02/28/09 12:17 AM
02/28/09 12:17 AM
calif
cupcake Offline
cupcake  Offline
calif
save ur money get a blower in the bottle
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: cupcake] #238495
02/28/09 01:18 AM
02/28/09 01:18 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Those intakes are an offenhauser 273 dual quad unit with the carb pads machined out and the blower pad welded in. As far as a kit there probably not available new anymore for mopars. You could buy the blower unit with the pulleys and have your own manifold made. Back in the 80s B&M ooffered an adapter to mount that small blower on any single plane street intake manifold.
Keep old mopars alive.
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: coronet1966d] #238496
02/28/09 08:39 AM
02/28/09 08:39 AM
ELYRIA,OH
ELYRIA,OH
to adapt a intake to a blower there is some information on victorylibrary.com in the tech paper section.
Re: roots blower for small block? 144, 174, 177 b&m wei [Re: blownzoom440] #238497
03/01/09 04:01 PM
03/01/09 04:01 PM
Chicagoland
chargerron69 Offline
Chicagoland
do a big block.... i have a 174 kit in the race parts section.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: roots blower for small block? 144, 174, 177 b&m wei [Re: chargerron69] #238498
03/01/09 04:10 PM
03/01/09 04:10 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Not sure if they still make them but Dick Landy used to make one.
http://www.dicklandy.com/Products/index.htm#Supercharger
Re: roots blower for small block? 144, 174, 177 b&m wei [Re: LilRed7879] #238499
03/01/09 04:13 PM
03/01/09 04:13 PM
Chicagoland
Chicagoland
i called dli when i got mu kit because i wanted to put it on 383 instead of 440 and they quoted 1000 to do just a manifold! they dont keep them in stock.
Re: roots blower for small block? 144, 174, 177 b&m wei [Re: chargerron69] #238500
03/01/09 05:09 PM
03/01/09 05:09 PM
MA
Greg55_99 Offline
Greg55_99  Offline
MA
For the type of manifold you want, the place is called Max Wedge Performance in Australia. They make them. Also makes one for W2 heads and some others. For more info contact:
"Bill Laney" <williaml@hotkey.net.au>
Got this message from Bill sometime back:
"Greg
Supercharged Chrysler small block 671 144-177 manifold AUD $1150 + freight
regards
Bill"
If you convert that to US dollars, it still ain't cheap. Pic is the 671 version he makes.
Greg
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: coronet1966d] #238501
03/01/09 06:58 PM
03/01/09 06:58 PM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Someone here posted a pic of a magnum beer barrel intake with the top wacked off and a blower mounting plate welded on. Looked sweet! Thought I saved the pic, but can't seem to find it...
Re: roots blower for small block? 144, 174, 177 b&m wei [Re: Greg55_99] #238502
03/02/09 01:20 PM
03/02/09 01:20 PM
"Greg
regards
Bill"
Greg
1,150.00 AUD = 726.241 USD
that could be worse i suppose but whats the blower itself going to run? and what else do i need to run it?
Re: roots blower for small block? 144, 174, 177 b&m wei [Re: coronet1966d] #238503
03/02/09 04:27 PM
03/02/09 04:27 PM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Thats the way it is for us guys into mopars. If you shell out $1100 plus for a custom made manifold- by the time you add in $$ for the blower and all accessories you are knocking on the price door of a good used 671 set up complete. As usual for SMC the small blower kit is very affordable and available new. I do know the Offy dual quad intakes are still available new and used, but the price for conversion seems to take the "Low Buck" out of the build.
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: FuryUs] #238504
03/02/09 04:59 PM
03/02/09 04:59 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
sounds very intersting, have been searching alot to find some pics of any kinds of blower manifold for a smallblock but cant find more than some pretty expensive ones made for 6/71s and some custom made ones in finland that do look nice but i kind of like the thougt of doing stuff myself
so any pics of this would be very intresting to see if it can be found:)
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: 1Fast340] #238505
10/20/12 02:44 PM
10/20/12 02:44 PM
Gilroy,CA.
mopardude318 Offline
Gilroy,CA.
I am reviving this thread because I am interested in obtaining one of these blowers for my 318...anyone have any updates?
Dragula, where did you obtain those pictures?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: mopardude318] #238506
10/21/12 01:35 PM
10/21/12 01:35 PM
Spanaway, Washington State
P
patosmith Offline
patosmith  Offline
P
My 2 cents:
I don't know how you plan to drive the car, race, show or both.
I have a blown 383 stroker motor in my 56 chevy wagon. (I am a mopar guy, I am working on a 72 challenger) The car is for show and I race it at the nastalgia drags a couple of times a year (high 11's et)
I did some research on the smaller B&M blowers when I built the motor.
The smaller blowers use 2 lobed rotors. The 671 and larger use 3 lobed rotors. The smaller blowers can cause pulsating boost pressures in the manifold because of the 2 lobe design plus they can't move as much air/fuel. I have seen guys at the strip with the small blowers and I am not saying they are bad but I wonder if they would have better et's with a bigger blower. I just wanted more performance if I was going to spend the $ for a blower. Also, the blower and carbs sticking out of the hood looks awsome! If you do decide to go with one of the smaller blowers I would suggest the 177, the largest capacity of the 3.
Re: roots blower for small block? 144, 174, 177 b&m weiand [Re: patosmith] #238507
10/21/12 01:42 PM
10/21/12 01:42 PM
Dragula Offline
Dragula  Offline
Only place I know where you can buy the small blowers now is:
http://www.theblowershop.com/category/20/BM-Weiand-Holley
