Re: roots blower for small block? 144, 174, 177 b&m weiand
[Re: cupcake]
#238495
02/28/09 12:18 AM
02/28/09 12:18 AM
Posts: 4,884 Holland MI Ottawa
2boltmain
Holland MI Ottawa
Those intakes are an offenhauser 273 dual quad unit with the carb pads machined out and the blower pad welded in. As far as a kit there probably not available new anymore for mopars. You could buy the blower unit with the pulleys and have your own manifold made. Back in the 80s B&M ooffered an adapter to mount that small blower on any single plane street intake manifold.
Keep old mopars alive.
[Re: LilRed7879]
#238499
03/01/09 03:13 PM
03/01/09 03:13 PM
Posts: 549 Chicagoland
chargerron69
Chicagoland
i called dli when i got mu kit because i wanted to put it on 383 instead of 440 and they quoted 1000 to do just a manifold! they dont keep them in stock.
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger
same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!!
72 Newport 2 door 400 727
85 Ram 440 4 speed O/D 3.54 dana
[Re: chargerron69]
#238500
03/01/09 04:09 PM
03/01/09 04:09 PM
Posts: 300 MA
Greg55_99
MA
For the type of manifold you want, the place is called Max Wedge Performance in Australia. They make them. Also makes one for W2 heads and some others. For more info contact:
"Bill Laney" <williaml@hotkey.net.au>
Got this message from Bill sometime back:
"Greg Supercharged Chrysler small block 671 144-177 manifold AUD $1150 + freight regards
Bill"
If you convert that to US dollars, it still ain't cheap. Pic is the 671 version he makes.
Greg
[Re: Greg55_99]
#238502
03/02/09 12:20 PM
03/02/09 12:20 PM
Posts: 2,682 Clinton Twp. Michigan
coronet1966d
Bill"
Greg
1,150.00 AUD = 726.241 USD
that could be worse i suppose but whats the blower itself going to run? and what else do i need to run it?
[Re: coronet1966d]
#238503
03/02/09 03:27 PM
03/02/09 03:27 PM
2boltmain
Holland MI Ottawa
Thats the way it is for us guys into mopars. If you shell out $1100 plus for a custom made manifold- by the time you add in $$ for the blower and all accessories you are knocking on the price door of a good used 671 set up complete. As usual for SMC the small blower kit is very affordable and available new. I do know the Offy dual quad intakes are still available new and used, but the price for conversion seems to take the "Low Buck" out of the build.
[Re: FuryUs]
#238504
03/02/09 03:59 PM
03/02/09 03:59 PM
Posts: 2,578 sweden
1Fast340
sweden
Someone here posted a pic of a magnum beer barrel intake with the top wacked off and a blower mounting plate welded on. Looked sweet! Thought I saved the pic, but can't seem to find it...
sounds very intersting, have been searching alot to find some pics of any kinds of blower manifold for a smallblock but cant find more than some pretty expensive ones made for 6/71s and some custom made ones in finland that do look nice but i kind of like the thougt of doing stuff myself so any pics of this would be very intresting to see if it can be found:)
[Re: 1Fast340]
#238505
10/20/12 01:44 PM
10/20/12 01:44 PM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
I am reviving this thread because I am interested in obtaining one of these blowers for my 318...anyone have any updates?
Dragula, where did you obtain those pictures?
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
