Trans fluid coming out of relocated vent on 904 #2384572
10/09/17 05:54 PM
10/09/17 05:54 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Have a 904 with relocated vent to the rear of the case (just in front of the tail shaft top of trans on drivers side. I can't remember who's brake is in the trans but that's the reason for vent relocation. When I make a pass the fluid blows out of the vent when in high gear. Not sure if I have too much fluid or something else is going on. Trans works well other than that.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Trans fluid coming out of relocated vent on 904 [Re: moparfan] #2384600
10/09/17 06:25 PM
10/09/17 06:25 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Plug the gov feed hole in the face of the park paw gear. John Kunkel posted a pic of the hole to plug. Maybe try a search.
Re: Trans fluid coming out of relocated vent on 904 [Re: moparfan] #2384663
10/09/17 07:39 PM
10/09/17 07:39 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
I grabbed this from Cope's old website which might help:
On 727s & 904s with Trans Brake or reverse pattern valve bodies, CRT recommends that you relocate the vent to the rear of the case. The stock vent is in the pump cover, fluid will leak out of the stock vent when using a trans brake. Drill the stock vent hole with a 11/23 drill bit, then tap the hole using a 1/8 pipe tap. Install 1/8 pipe plug. drill hole at the 11 O clock piston in the rear of case as shown in picture above and install new vent.
Also block off the feed hole in the park gear, or you will have fluid spitting out the vent. See pic below
Re: Trans fluid coming out of relocated vent on 904 [Re: humpty] #2384702
10/09/17 08:43 PM
10/09/17 08:43 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Thanks, doesn't look like an easy fix in the car
2021 T/A 392
2020 Hellcat redeye
Re: Trans fluid coming out of relocated vent on 904 [Re: moparfan] #2384706
10/09/17 08:48 PM
10/09/17 08:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If all else fails put a catch can on it. This is a powerglide but they make them for everything and I got mine from Summit.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trans fluid coming out of relocated vent on 904 [Re: moparfan] #2384732
10/09/17 09:36 PM
10/09/17 09:36 PM
Ambridge, Pa.
Ambridge, Pa.
It's not that bad. Support the trans, open the snap ring on the rear bearing( make sure u keep the output shaft pushed in so the thrust washer doesn't fall out). Remove the roller bearing, take the park paw gear off. If the govnor is in there, which it shouldn't b, leave the guts out. Tap the hole, I think 10/32, can't really remember exactly. Reassemble.
Re: Trans fluid coming out of relocated vent on 904 [Re: moparfan] #2384777
10/09/17 10:46 PM
10/09/17 10:46 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
You can use hard plastic or rubber tubing to go either in or over the plastic breather and run to a small catch can. Use a bottom fitting on the catch can so the fluid will drain back.
Re: Trans fluid coming out of relocated vent on 904 [Re: moparfan] #2384808
10/09/17 11:28 PM
10/09/17 11:28 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I have a 1/4 air line fitting on mine. It's the quick connect type used in most air bag kits. Line runs to a vented catch can under the hood.
Re: Trans fluid coming out of relocated vent on 904 [Re: J_BODY] #2384840
10/10/17 12:33 AM
10/10/17 12:33 AM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Thanks for all the good ideas. I can't remember if the vent is threaded in or not. I'll check to see if I can rig a catch can to it. I don't race the car that much and doesn't seem to do it when I beat it on the street. typically not getting into high gear I guess.
2021 T/A 392
2020 Hellcat redeye
