Trans fluid coming out of relocated vent on 904
#2384572
10/09/17 05:54 PM
10/09/17 05:54 PM
Posts: 482 Marysville Wa
moparfan
Marysville Wa
Have a 904 with relocated vent to the rear of the case (just in front of the tail shaft top of trans on drivers side. I can't remember who's brake is in the trans but that's the reason for vent relocation. When I make a pass the fluid blows out of the vent when in high gear. Not sure if I have too much fluid or something else is going on. Trans works well other than that.
2017 Challenger R/T Scat Pack Shaker 2021 T/A 392 1970 Challenger R/T 383,727, 3.55, (Wife's car) 1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana 1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85 2020 Hellcat redeye
Re: Trans fluid coming out of relocated vent on 904
[Re: humpty]
#2384702
10/09/17 08:43 PM
10/09/17 08:43 PM
moparfan
Marysville Wa
Thanks, doesn't look like an easy fix in the car
[Re: moparfan]
#2384706
10/09/17 08:48 PM
10/09/17 08:48 PM
Posts: 20,179 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Thanks, doesn't look like an easy fix in the car If all else fails put a catch can on it. This is a powerglide but they make them for everything and I got mine from Summit. Untitled by John Cadamore, on Flickr
[Re: moparfan]
#2384732
10/09/17 09:36 PM
10/09/17 09:36 PM
Posts: 2,408 Ambridge, Pa.
rickraw
Ambridge, Pa.
It's not that bad. Support the trans, open the snap ring on the rear bearing( make sure u keep the output shaft pushed in so the thrust washer doesn't fall out). Remove the roller bearing, take the park paw gear off. If the govnor is in there, which it shouldn't b, leave the guts out. Tap the hole, I think 10/32, can't really remember exactly. Reassemble.
[Re: J_BODY]
#2384840
10/10/17 12:33 AM
10/10/17 12:33 AM
moparfan
Marysville Wa
Thanks for all the good ideas. I can't remember if the vent is threaded in or not. I'll check to see if I can rig a catch can to it. I don't race the car that much and doesn't seem to do it when I beat it on the street. typically not getting into high gear I guess.
