452 heads any good for performance? #2383949
10/08/17 04:20 PM
10/08/17 04:20 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Just curious if they can make any power after porting or clean up. I have a pair from the 400 I just bought, would like to sell.
Re: 452 heads any good for performance? [Re: mopar dave] #2383957
10/08/17 04:34 PM
10/08/17 04:34 PM
Deerfield, Ohio
70dusterjohn Offline
Deerfield, Ohio
Had a set on a 440 that flowed better than my old 906s .. the other good thing is the have the hardened valve seats for unleaded fuels..
Re: 452 heads any good for performance? [Re: 70dusterjohn] #2383962
10/08/17 04:42 PM
10/08/17 04:42 PM
Mt Morris Michigan
Mt Morris Michigan
cool! maybe I can get something out of them. any idea what their worth needing cleaning up? they probably need everything.
Re: 452 heads any good for performance? [Re: mopar dave] #2383965
10/08/17 04:46 PM
10/08/17 04:46 PM
Deerfield, Ohio
Deerfield, Ohio
The last set I sold that where stock I got 150 out of them. I don't know what the market is now ..
Re: 452 heads any good for performance? [Re: 70dusterjohn] #2383981
10/08/17 05:12 PM
10/08/17 05:12 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks
Re: 452 heads any good for performance? [Re: mopar dave] #2383986
10/08/17 05:16 PM
10/08/17 05:16 PM
Deerfield, Ohio
Deerfield, Ohio
Re: 452 heads any good for performance? [Re: 70dusterjohn] #2384017
10/08/17 06:03 PM
10/08/17 06:03 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
Is there any of the hardened seat left after installing 1.81 exh valves?
Re: 452 heads any good for performance? [Re: B5 Bee] #2384251
10/09/17 01:53 AM
10/09/17 01:53 AM
Mopar Country, Mi
ccdave Offline
The Ultimate
ccdave  Offline
The Ultimate
Mopar Country, Mi
452 heads can be decent if your willing to spend the money to make them flow. Here is a set I did a few years ago. The customer spent 1200 big ones. At this point I would rather point customers to aftermarket heads. 452 cores are worth 100-200 bucks
2B5B6A01-5ED2-40BA-8D2D-42EFB382A0D1.jpegFAC0B26A-CBA9-4F40-B877-67D0BA5D84A6.jpegE681AC9F-490A-447D-BF8E-2C93603255CB.jpeg87278B15-D596-49B3-A149-97878A02BFF3.jpeg
Re: 452 heads any good for performance? [Re: ccdave] #2384277
10/09/17 04:05 AM
10/09/17 04:05 AM
Herb McCandless bought a bunch of the 452 cores back when Mopar decided to lower their inventory years ago, he did some porting and testing on them and got one of the magazine writers to do a feature article on how good they where whistling work
That was before Zeeker was opened and offering new aluminum heads shruggy
That magazine article helped Herb sell a lot of those heads whistling shruggy
Re: 452 heads any good for performance? [Re: ccdave] #2384313
10/09/17 10:02 AM
10/09/17 10:02 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Yep. If you have to pay someone else to do the work, they won't be cost effective compared to the aftermarket offerings.
Re: 452 heads any good for performance? [Re: BradH] #2384331
10/09/17 10:56 AM
10/09/17 10:56 AM
Mt Morris Michigan
Mt Morris Michigan
Good to know they have some potential. I will be happy to get $100. Ill get those off the block and see how they look. Thanks
Re: 452 heads any good for performance? [Re: mopar dave] #2384355
10/09/17 11:49 AM
10/09/17 11:49 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
I've got 4 sets here on my basement floor. Put an ad on the Milan Dragway fb page about a year ago. $40/pair. Got 1 guy interested, locally, that was going to come over after his next payday. Still waiting.
Got several inquiries for 915's from far reaching states (TX being one).
Re: 452 heads any good for performance? [Re: Dean_Kuzluzski] #2384358
10/09/17 11:54 AM
10/09/17 11:54 AM
Mt Morris Michigan
Mt Morris Michigan
Didnt think they would be a easy sale. Racejunk maybe?
Re: 452 heads any good for performance? [Re: mopar dave] #2384377
10/09/17 12:24 PM
10/09/17 12:24 PM
Dulcich has a very good porting article on them, worth reading. If you Google it I'm sure you can locate it. EDIT "dulcich mopar porting articles"
Re: 452 heads any good for performance? [Re: mopar dave] #2384394
10/09/17 12:45 PM
10/09/17 12:45 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I don't think you'd find many performance head shops to refurbish an old set of iron heads, install all new performance oriented parts, and port them....... For anywhere near what you can buy a set of E-Street heads for.
About the only time I do iron heads anymore is for resto type builds, or where the rules require it.
IMO, the cores only have any value at all if they aren't cracked....... Which is often pretty hard to know until they're cleaned and magged(about $100).
Cleaned, magged cores that check out good are probably worth $150-200...... To someone that really has to have a set.
Unknown cores? $40 max IMO........knowing you're taking a gamble on them.
Re: 452 heads any good for performance? [Re: fast68plymouth] #2384421
10/09/17 01:16 PM
10/09/17 01:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Your wasting your time keeping them.. you wont
ever sell them.. all they are doing is taking
up good space
wave
Re: 452 heads any good for performance? [Re: mopar dave] #2384452
10/09/17 02:20 PM
10/09/17 02:20 PM
Idaho
LaRoy Engines Offline
Idaho
Those old 452 iron heads are not worth messing with unless you have to run iron. We did a $1,900 set back in 2006 for a 451 stroker. 9.5:1 compression, 91 octane pump gas, solid roller, ported M1 single plane, 950cfm Quick Fuel 4150. It did however make 588 LB-FT @ 4,600 rpm and 621 HP @ 6,100 rpm. So........there is some potential in them.
Re: 452 heads any good for performance? [Re: LaRoy Engines] #2384464
10/09/17 02:42 PM
10/09/17 02:42 PM
MR_P_BODY Offline
MR_P_BODY  Offline
When was the last time you ported any iron
heads.. I wont even waste my time to go look
at a set now days
wave
Re: 452 heads any good for performance? [Re: LaRoy Engines] #2384515
10/09/17 04:13 PM
10/09/17 04:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
What would that be in 2017 dollars?
Re: 452 heads any good for performance? [Re: MR_P_BODY] #2384518
10/09/17 04:16 PM
10/09/17 04:16 PM
So. Burlington, Vt.
So. Burlington, Vt.
heads.
I do a few sets every year.
I did a set this spring, and have 3 more sets here to do now.
