Re: 452 heads any good for performance?
[Re: 70dusterjohn]
#2384017
10/08/17 06:03 PM
10/08/17 06:03 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Had a set on a 440 that flowed better than my old 906s .. the other good thing is the have the hardened valve seats for unleaded fuels.. Is there any of the hardened seat left after installing 1.81 exh valves?
[Re: ccdave]
#2384277
10/09/17 04:05 AM
10/09/17 04:05 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
[Re: ccdave]
#2384313
10/09/17 10:02 AM
10/09/17 10:02 AM
BradH
452 heads can be decent if your willing to spend the money to make them flow. Here is a set I did a few years ago. The customer spent 1200 big ones. At this point I would rather point customers to aftermarket heads. 452 cores are worth 100-200 bucks Yep. If you have to pay someone else to do the work, they won't be cost effective compared to the aftermarket offerings.
[Re: mopar dave]
#2384355
10/09/17 11:49 AM
10/09/17 11:49 AM
Posts: 8,941 Holly/MI
Dean_Kuzluzski
Holly/MI
I've got 4 sets here on my basement floor. Put an ad on the Milan Dragway fb page about a year ago. $40/pair. Got 1 guy interested, locally, that was going to come over after his next payday. Still waiting. Got several inquiries for 915's from far reaching states (TX being one).
[Re: mopar dave]
#2384377
10/09/17 12:24 PM
10/09/17 12:24 PM
RapidRobert
Dulcich has a very good porting article on them, worth reading. If you Google it I'm sure you can locate it. EDIT "dulcich mopar porting articles"
[Re: mopar dave]
#2384394
10/09/17 12:45 PM
10/09/17 12:45 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I don't think you'd find many performance head shops to refurbish an old set of iron heads, install all new performance oriented parts, and port them....... For anywhere near what you can buy a set of E-Street heads for.
About the only time I do iron heads anymore is for resto type builds, or where the rules require it.
IMO, the cores only have any value at all if they aren't cracked....... Which is often pretty hard to know until they're cleaned and magged(about $100).
Cleaned, magged cores that check out good are probably worth $150-200...... To someone that really has to have a set.
Unknown cores? $40 max IMO........knowing you're taking a gamble on them.
[Re: fast68plymouth]
#2384421
10/09/17 01:16 PM
10/09/17 01:16 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Your wasting your time keeping them.. you wont ever sell them.. all they are doing is taking up good space
[Re: mopar dave]
#2384452
10/09/17 02:20 PM
10/09/17 02:20 PM
Posts: 559 Idaho
LaRoy Engines
Idaho
Those old 452 iron heads are not worth messing with unless you have to run iron. We did a $1,900 set back in 2006 for a 451 stroker. 9.5:1 compression, 91 octane pump gas, solid roller, ported M1 single plane, 950cfm Quick Fuel 4150. It did however make 588 LB-FT @ 4,600 rpm and 621 HP @ 6,100 rpm. So........there is some potential in them.
[Re: LaRoy Engines]
#2384464
10/09/17 02:42 PM
10/09/17 02:42 PM
MR_P_BODY
When was the last time you ported any iron heads.. I wont even waste my time to go look at a set now days
[Re: LaRoy Engines]
#2384515
10/09/17 04:13 PM
10/09/17 04:13 PM
fast68plymouth
So. Burlington, Vt.
We did a $1,900 set back in 2006 for a 451 stroker. What would that be in 2017 dollars?
[Re: MR_P_BODY]
#2384518
10/09/17 04:16 PM
10/09/17 04:16 PM
fast68plymouth
So. Burlington, Vt.
When was the last time you ported any iron heads. I do a few sets every year. I did a set this spring, and have 3 more sets here to do now.
