NASTY MISFIRING / 95 CONCORDE #2383436
10/07/17 02:52 PM
10/07/17 02:52 PM
S.E.Ohio
Magnumguy Offline OP
S.E.Ohio
95 3.5
Was misfiring under load slightly before, it has been setting for a couple-three months at a shop waiting for strut repair (had to order a new spindle). Picked it up last night and man is it running rough. Idles OK, and doesn't seem to misfire much at steady throttle, but step into it any and it misses horribly, and not steady like one cylinder is the culprit.
Acceleration is horrible, and rough. Takes forever to get up to speed. 1st thought is wires. Did put injector cleaner in it today, but only a short run home.
Thoughts?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383454
10/07/17 03:54 PM
10/07/17 03:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
CODES?
Don't be the exception.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383459
10/07/17 04:02 PM
10/07/17 04:02 PM
S.E.Ohio
S.E.Ohio
None. Check engine light is always on.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383467
10/07/17 04:14 PM
10/07/17 04:14 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Then it has codes.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383478
10/07/17 04:43 PM
10/07/17 04:43 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Check your fuel pressure yet? Weak pump could be starving it under load and lean condition will set your check engine light.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383508
10/07/17 06:06 PM
10/07/17 06:06 PM
S.E.Ohio
S.E.Ohio
Pump is original, it's just shy of 200,000
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383527
10/07/17 06:52 PM
10/07/17 06:52 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
Pull the plug wires and look for a burn hole in the side of the insulator.
Also, ck for corrosion on top of the plug itself / inside the boot. Do the same for the coil pack end . If so, replace them do not try to clean them .
PS, if the ck engine light is on there's a fault stored.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383547
10/07/17 07:54 PM
10/07/17 07:54 PM
S.E.Ohio
S.E.Ohio
the fault is the EGR. It's been like this since I bought it years ago. Comes on after running a bit. Always has.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383632
10/07/17 11:35 PM
10/07/17 11:35 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
If its misfiring it should have a misfire code.have the codes pulled.Rocky
Chrysler Firepower
Re: NASTY MISFIRING / 95 CONCORDE [Re: DaytonaTurbo] #2383691
10/08/17 01:44 AM
10/08/17 01:44 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
This is where I would start, too.
It's Swifty! Swifty, you toad sucker!
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383915
10/08/17 03:16 PM
10/08/17 03:16 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
If check engine light has always been on, there may be more than one issue. Don't take it for granted that it is on due to that same ongoing issue. Get it scanned.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2383923
10/08/17 03:29 PM
10/08/17 03:29 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Advance AZ its free to scan codes.Wont be as good as reading data but its a starting point.Rocky
Chrysler Firepower
Re: NASTY MISFIRING / 95 CONCORDE [Re: therocks] #2384055
10/08/17 07:21 PM
10/08/17 07:21 PM
S.E.Ohio
S.E.Ohio
Being a '95,will they still be able to? Most it seems won't do a 95 and back?
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2384072
10/08/17 07:57 PM
10/08/17 07:57 PM
Corpus Christi, TX
shanker Offline
shanker  Offline
Corpus Christi, TX
I have a 2004 Intrepid (my wife's car that I HATE!!!)
When I changed the fuel pump on this car, I realized that there is NO FUEL FILTER....the fuel pump assembly uses a built in filter..
I'm currently doing a head gasket job on it. (i've ALMOST got the drivers side head off)....now that I've spent 2 days hunkered over this car, I would have rather traded it in on something else even though we're not in a position to buy a new car....
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2384108
10/08/17 09:15 PM
10/08/17 09:15 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Cant remember when they went OBD 2 But I beieve it was 94 or 95.Been a long time since Ive done one.Code reader if OBD2 should read it.Rocky
Chrysler Firepower
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2384118
10/08/17 09:37 PM
10/08/17 09:37 PM
S.E.Ohio
S.E.Ohio
Got it scheduled to be looked at this week.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2384136
10/08/17 10:23 PM
10/08/17 10:23 PM
Cleveland Ohio
sportfury70 Offline
sportfury70  Offline
Cleveland Ohio
Obd2 was 96
Re: NASTY MISFIRING / 95 CONCORDE [Re: shanker] #2384210
10/09/17 12:24 AM
10/09/17 12:24 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
2003 3.5 concorde developed a nasty misfire when under load. All sorts of BS and head scratching until I discovered my dad put autolites in there. I about cussed him out and told him dont ever put that garbage on anything I have to work on. NGK only
most stuff has used the 'all in one' approach for the last 15-20 years now. Does cost more but it seems like the reliability has also gone up quite a bit. One fuel module replacement in my 03 Concorde , my 94 Shadow will be on pump #5 here soon.
Re: NASTY MISFIRING / 95 CONCORDE [Re: Magnumguy] #2384248
10/09/17 01:46 AM
10/09/17 01:46 AM
S.E.Ohio
S.E.Ohio
Still has the original fpump @ 198,000 miles. Probably the culprit.
Re: NASTY MISFIRING / 95 CONCORDE [Re: sportfury70] #2384492
10/09/17 03:25 PM
10/09/17 03:25 PM
It's a dry heat
It's a dry heat
Originally Posted By sportfury70
Obd2 was 96
True, EXCEPT
But 1st year Neons were OBD2 in 1995
Doubt it, OBD1 cars the connector was manufacture specific and not likely these stores will have the equipment
