Re: NASTY MISFIRING / 95 CONCORDE
[Re: Magnumguy]
#2383632
10/07/17 11:35 PM
10/07/17 11:35 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
If its misfiring it should have a misfire code.have the codes pulled.Rocky
Chrysler Firepower
[Re: DaytonaTurbo]
#2383691
10/08/17 01:44 AM
10/08/17 01:44 AM
Posts: 905 SD
zrxkawboy
SD
Check your fuel pressure yet? Weak pump could be starving it under load This is where I would start, too.
It's Swifty! Swifty, you toad sucker!
[Re: Magnumguy]
#2383923
10/08/17 03:29 PM
10/08/17 03:29 PM
therocks
Niles , Ohio
Advance AZ its free to scan codes.Wont be as good as reading data but its a starting point.Rocky
Chrysler Firepower
[Re: therocks]
#2384055
10/08/17 07:21 PM
10/08/17 07:21 PM
Posts: 10,645 S.E.Ohio
Magnumguy
S.E.Ohio
Advance AZ its free to scan codes.Wont be as good as reading data but its a starting point.Rocky Being a '95,will they still be able to? Most it seems won't do a 95 and back?
[Re: Magnumguy]
#2384072
10/08/17 07:57 PM
10/08/17 07:57 PM
Posts: 5,784 Corpus Christi, TX
shanker
Corpus Christi, TX
I have a 2004 Intrepid (my wife's car that I HATE!!!)
When I changed the fuel pump on this car, I realized that there is NO FUEL FILTER....the fuel pump assembly uses a built in filter..
I'm currently doing a head gasket job on it. (i've ALMOST got the drivers side head off)....now that I've spent 2 days hunkered over this car, I would have rather traded it in on something else even though we're not in a position to buy a new car....
The Federal Government has not yet learned that you cannot legislate morality
1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23
1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55
1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91
1975 Duster 360 VS29L5 Daily Driver
[Re: Magnumguy]
#2384108
10/08/17 09:15 PM
10/08/17 09:15 PM
therocks
Niles , Ohio
Cant remember when they went OBD 2 But I beieve it was 94 or 95.Been a long time since Ive done one.Code reader if OBD2 should read it.Rocky
Chrysler Firepower
[Re: shanker]
#2384210
10/09/17 12:24 AM
10/09/17 12:24 AM
Posts: 637 SoMd, USA
135sohc
SoMd, USA
2003 3.5 concorde developed a nasty misfire when under load. All sorts of BS and head scratching until I discovered my dad put autolites in there. I about cussed him out and told him dont ever put that garbage on anything I have to work on. NGK only I have a 2004 Intrepid (my wife's car that I HATE!!!)
I'm currently doing a head gasket job on it. (i've ALMOST got the drivers side head off)....now that I've spent 2 days hunkered over this car, I would have rather traded it in on something else even though we're not in a position to buy a new car.... most stuff has used the 'all in one' approach for the last 15-20 years now. Does cost more but it seems like the reliability has also gone up quite a bit. One fuel module replacement in my 03 Concorde , my 94 Shadow will be on pump #5 here soon.
[Re: sportfury70]
#2384492
10/09/17 03:25 PM
10/09/17 03:25 PM
Posts: 21,442 It's a dry heat
gtx6970
It's a dry heat
True, EXCEPT But 1st year Neons were OBD2 in 1995 Advance AZ its free to scan codes.Wont be as good as reading data but its a starting point.Rocky Being a '95,will they still be able to? Most it seems won't do a 95 and back? Doubt it, OBD1 cars the connector was manufacture specific and not likely these stores will have the equipment
