Does this tire look safe? #2383875
10/08/17 02:12 PM
10/08/17 02:12 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Does this look like a useable tire?
Re: Does this tire look safe? [Re: Jeff_383] #2383884
10/08/17 02:22 PM
10/08/17 02:22 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Sure, if you want to paint it white and plant flowers in it... whistling
Re: Does this tire look safe? [Re: DrCharles] #2383892
10/08/17 02:31 PM
10/08/17 02:31 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
That's kinda my thought as well
Re: Does this tire look safe? [Re: Jeff_383] #2383969
10/08/17 04:53 PM
10/08/17 04:53 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
How old is it? How deep are the cuts? It MAY be ok for a show car, not for ANY performance use, even a burnout. twocents
Re: Does this tire look safe? [Re: Jeff_383] #2383996
10/08/17 05:30 PM
10/08/17 05:30 PM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
I had a tire with cuts in the sidewall, similar to what you are showing . . . and it was almost a new tire. No way was I going to take a chance on the highway . . . spend the $$ for new tire.
Re: Does this tire look safe? [Re: Jeff_383] #2384149
10/08/17 10:38 PM
10/08/17 10:38 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
You know the answer...Or you wouldn't be asking if it was safe...Even if someone said to run it would you ?? What cut into it on the backside ???
Re: Does this tire look safe? [Re: screamindriver] #2384160
10/08/17 10:47 PM
10/08/17 10:47 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Probably the fender lip. Then the person swapped the tire on the rim to hide the cuts.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Does this tire look safe? [Re: amxautox] #2384186
10/08/17 11:25 PM
10/08/17 11:25 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
My guess is the inner wheel well. I inquired to buy and the pic I got was this one. Said was only driven for a block.
Re: Does this tire look safe? [Re: Jeff_383] #2384496
10/09/17 03:30 PM
10/09/17 03:30 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
haha
After it was remounted.
Sad thing is someone will buy it,and probably try to use it, or put it on a car for sale.
I have mechanical Aptitude.
I can screw up anything.
Re: Does this tire look safe? [Re: Jeff_383] #2384500
10/09/17 03:36 PM
10/09/17 03:36 PM
Any time your in doubt about safety items on our cars, change it out or do without up twocents
You knew that already, correct thumbs
Re: Does this tire look safe? [Re: Jeff_383] #2385025
10/10/17 12:21 PM
10/10/17 12:21 PM
Long Island, NY
shocktrp Offline
shocktrp  Offline
Long Island, NY
Probably usable as a roller if you're sending the car to a paint booth.
I wouldn't drive on it though.
