Re: Does this tire look safe?
[Re: screamindriver]
#2384160
10/08/17 10:47 PM
10/08/17 10:47 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
You know the answer...Or you wouldn't be asking if it was safe...Even if someone said to run it would you ?? What cut into it on the backside ??? Probably the fender lip. Then the person swapped the tire on the rim to hide the cuts.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: amxautox]
#2384186
10/08/17 11:25 PM
10/08/17 11:25 PM
Posts: 877 Pittsburgh, Pa
Jeff_383
Pittsburgh, Pa
My guess is the inner wheel well. I inquired to buy and the pic I got was this one. Said was only driven for a block.
[Re: Jeff_383]
#2384496
10/09/17 03:30 PM
10/09/17 03:30 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Said was only driven for a block. After it was remounted. Sad thing is someone will buy it,and probably try to use it, or put it on a car for sale.
I have mechanical Aptitude. I can screw up anything.
