2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number #2382813
10/06/17 02:01 AM
10/06/17 02:01 AM
usa
Trailers4Sale Offline OP
usa
I have seen two variations of the 2863215 7 blade engine cooling fan. One version has the part number ink stamped on one of the blades and the other version has the part number stamped into the metal at the end of one of the blades. I am looking to buy a correct one for my 69 Hemi. On ebay one of the sellers states that he believes that the ink stamped version is correct for pre 70 and the metal stamped version is correct for 70 and later. Does anybody know for certain if this is true?...Thanks
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2382851
10/06/17 08:22 AM
10/06/17 08:22 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
My understating is that the ink stamped one came on 69 down like you have been told. I have pulled several off of cars in the wrecking yards. I may have an extra one. PM me if you are interested.
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2382879
10/06/17 10:56 AM
10/06/17 10:56 AM
Brownstown, PA
FJR doc Offline
FJR doc  Offline
Brownstown, PA
My 1970 Duster 340 had an ink stamped part number on the fan blade.
Follow my Duster 340 restoration progress on FABO http://www.forabodiesonly.com/mopar/showthread.php?t=225784
Kevin
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2382948
10/06/17 01:43 PM
10/06/17 01:43 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Just checked my 68 Hemi Charger which I am sure is all original - it has no stamped numbers
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2383046
10/06/17 05:01 PM
10/06/17 05:01 PM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
Looking at the ones I have in the shop, I think it would be very easy to wipe the white numbers off pretty easily. Things don’t rust in my area like they do in some places but the sun gets hot enough to bake paint.
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: fastmark] #2383057
10/06/17 05:43 PM
10/06/17 05:43 PM
Fort Worth, Texas
xs29j8 Offline
xs29j8  Offline
Fort Worth, Texas
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: xs29j8] #2383078
10/06/17 06:59 PM
10/06/17 06:59 PM
usa
usa
I just confirmed that the Hemi Daytona currently owned by David Spade, which by the way is for sale, had the 215 fan that had the part number stamped into the metal. Therefore it looks like I will buy one of the NOS fans pictured in the previous post.
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2383137
10/06/17 09:43 PM
10/06/17 09:43 PM
Southeast Virginia
68jim Offline
68jim  Offline
Southeast Virginia
Not to hijack the thread but which one had a wider range of applications - ink stamped or metal stamped?
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2383311
10/07/17 09:43 AM
10/07/17 09:43 AM
USA
Suregrip391 Online content
Suregrip391  Online Content
USA
Does the 215 have a different pitch then the 216? Which moves more air?
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Suregrip391] #2383324
10/07/17 10:42 AM
10/07/17 10:42 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Yes there is a noticeable difference in the two as seen on the ends of each blade.
Also 216 is 18.5 inches , 215 is 18 inches.
First picture 216 in front, 215 in rear.
Second picture shows end cut difference as well,
215 in front, 216 in rear
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2383347
10/07/17 11:33 AM
10/07/17 11:33 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
From what I have seen on the ones I have bought from wrecking yards and labeled them, the 215 fans are on 340 and 69 down high rpm cars. The a12 cars started the 216 with the big rad. Most 340 a body cars got the 215. Both fans could come one any application so you can find them on anything. I’m sure the stamped ones Alan has are NOS bought well into the 70’s or 80’s and would be the ones last made and sold through dealers. Most of the earlier cars I have seen had the ink stamped. They changed at some time to the stamped ones.
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: Trailers4Sale] #2383389
10/07/17 01:15 PM
10/07/17 01:15 PM
NJ
JH23 Offline
JH23  Offline
NJ
Do both style fans use the same shroud?
Re: 2863215 Fan Blade Ink Stamp vs Metal Stamped Part Number [Re: JH23] #2383391
10/07/17 01:19 PM
10/07/17 01:19 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
For the most part yes but your shroud is more a function of the radiator it is attached to.
