New Tires on DD:
#2383130
10/06/17 09:20 PM
10/06/17 09:20 PM
Posts: 8,399 Highland, MI.
Sunroofcuda
Highland, MI.
Just ordered in tires a day ago for my 2014 Chrysler 300 - some Firestones. I had them installed today & they really felt pumped-up so I checked the pressure when I got home. The installer had them inflated to 43-44 lbs. I always thought the rule was around 32 psi for a regular set of tires on a car, so I adjusted them all down to 35 psi.
What do you guys keep your daily driver tires inflated to?
Re: New Tires on DD:
[Re: Sunroofcuda]
#2383131
10/06/17 09:22 PM
10/06/17 09:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What do you guys keep your daily driver tires inflated to? The rule is to inflate them at the PSI specified on the door jamb sticker.
[Re: topside]
#2383143
10/06/17 09:48 PM
10/06/17 09:48 PM
Supercuda
About to go away
About to go away
up yours
I typically run 32 PSI in most of the cars, generally sticking to the higher #s posted on the sidewalls. Some combinations of tread & rim width want more or less to get the full footprint, so I've run as high as 40 in some cases. I assume stock sizes on stock rims on a DD, which means stock PSI, aka door jamb sticker.
[Re: ahy]
#2383203
10/06/17 11:25 PM
10/06/17 11:25 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
I just had a set of Kumho XL's mounted last week at my local Firestone. I have used them for five sets of tires and they usually set the tire psi to what is on the door. This set they had them all at 40psi and I felt it on the drive home. After a quick couple of chalk tests, I lowered the pressure down to 36 front and 34 rear.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
[Re: 71birdJ68]
#2383207
10/06/17 11:30 PM
10/06/17 11:30 PM
Sunroofcuda
Highland, MI.
I really like DDs, especially firm ones. Har-de-harr-harr! Honey, if I told you you had beautiful DD's, would you hold it against me?
