New Tires on DD: #2383130
10/06/17 09:20 PM
10/06/17 09:20 PM
Highland, MI.
Sunroofcuda Offline OP
Highland, MI.
Just ordered in tires a day ago for my 2014 Chrysler 300 - some Firestones. I had them installed today & they really felt pumped-up so I checked the pressure when I got home. The installer had them inflated to 43-44 lbs. I always thought the rule was around 32 psi for a regular set of tires on a car, so I adjusted them all down to 35 psi.
What do you guys keep your daily driver tires inflated to?
Re: New Tires on DD: [Re: Sunroofcuda] #2383131
10/06/17 09:22 PM
10/06/17 09:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The rule is to inflate them at the PSI specified on the door jamb sticker.
Don't be the exception.
Re: New Tires on DD: [Re: Sunroofcuda] #2383135
10/06/17 09:40 PM
10/06/17 09:40 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I typically run 32 PSI in most of the cars, generally sticking to the higher #s posted on the sidewalls. Some combinations of tread & rim width want more or less to get the full footprint, so I've run as high as 40 in some cases.
Re: New Tires on DD: [Re: topside] #2383143
10/06/17 09:48 PM
10/06/17 09:48 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I assume stock sizes on stock rims on a DD, which means stock PSI, aka door jamb sticker.
Re: New Tires on DD: [Re: topside] #2383152
10/06/17 09:54 PM
10/06/17 09:54 PM
IN
ahy Offline
ahy  Offline
IN
I generally run 35 psi minimum. Or the door jamb pressure if higher (usually not).
More pressure if running fast or heavy. I do watch wear patterns... I have not seen evidence of excess center wear at 35 psi on DD's.
I also have found tire stores inflate high. After past issues with low inflation on Explorers I guess they want to be "safe" from a liability perspective.
I like to get the car home after tire service, let it cool, and adjust pressure as I think you have.
Re: New Tires on DD: [Re: ahy] #2383192
10/06/17 10:55 PM
10/06/17 10:55 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
I really like DDs, especially firm ones.
Re: New Tires on DD: [Re: ahy] #2383203
10/06/17 11:25 PM
10/06/17 11:25 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
I just had a set of Kumho XL's mounted last week at my local Firestone. I have used them for five sets of tires and they usually set the tire psi to what is on the door. This set they had them all at 40psi and I felt it on the drive home. After a quick couple of chalk tests, I lowered the pressure down to 36 front and 34 rear.
Re: New Tires on DD: [Re: 71birdJ68] #2383207
10/06/17 11:30 PM
10/06/17 11:30 PM
Highland, MI.
Highland, MI.
Har-de-harr-harr! Honey, if I told you you had beautiful DD's, would you hold it against me?
