Cleaning Aluminum Intake #2382532
10/05/17 05:03 PM
10/05/17 05:03 PM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
Any ideas on taking the paint off a Victor intake without damaging the aluminum. I know you can have it blasted but hoping I could just soak it in some sort of chemical to clean it.
Re: Cleaning Aluminum Intake [Re: 80fbody] #2382535
10/05/17 05:09 PM
10/05/17 05:09 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Paint stripper. It may take multiple applications and a stiff brush to get it 100% clean.
Re: Cleaning Aluminum Intake [Re: 80fbody] #2382644
10/05/17 08:40 PM
10/05/17 08:40 PM
Maryland
MoparMike1974 Offline
Maryland
Depending on how pourous the casting is will determine if paint stripper will get it all off. Glass bead would be my choice.
Re: Cleaning Aluminum Intake [Re: MoparMike1974] #2382698
10/05/17 10:07 PM
10/05/17 10:07 PM
IN
ahy Offline
ahy  Offline
IN
A heavy coat of aircraft paint stripper and wrap in plastic to keep it moist would be my suggestion. After that scrape and/or pressure wash. For final clean, by hand or even a dishwasher.
Glass bead can work well on manifolds... but very thorough cleaning required after. If any glass gets into a running engine, not good.
