Plugs and plug wire recommendations needed
#2382465
10/05/17 03:13 PM
10/05/17 03:13 PM
Posts: 368 michigan
turbo toad
michigan
Its been awhile since I posted but I'm buttoning up my build and I'm to the point where I'm in need of some info on plugs and wires for my junk. HEI style dizzy E85 fuel Indy 440-1 heads 10-15 psi of boost Big block low deck in a abody
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Plugs and plug wire recommendations needed
[Re: turbo toad]
#2382675
10/05/17 09:26 PM
10/05/17 09:26 PM
Posts: 13,360 Marion, South Carolina [><]
an8sec70cuda
NGK plugs and either MSD or Taylor for wires.
[Re: turbo toad]
#2382842
10/06/17 05:16 AM
10/06/17 05:16 AM
Posts: 5,762 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Tell em what it is 😆 I know your about to fire it. You better post vids 👌
I wish I was closer so I could help.
[Re: turbo toad]
#2382850
10/06/17 08:17 AM
10/06/17 08:17 AM
Posts: 368 michigan
turbo toad
michigan
Thanks guys
Fastmop ill get some video and post it up.
There's only a couple minor things left to do and I hope to have things buttoned up minis the turbos plumbing By next week.
[Re: turbo toad]
#2382903
10/06/17 11:49 AM
10/06/17 11:49 AM
Posts: 21,067 Niles , Ohio
therocks
Niles , Ohio
NGK and Taylor Spiro pro wires.last set I had on for at least 15 years.Thats with headers on a BB.Run them on everything.Replaced mine because they looked nasty but still worked like new.Rocky
Chrysler Firepower
[Re: turbo toad]
#2382916
10/06/17 12:14 PM
10/06/17 12:14 PM
Posts: 368 michigan
turbo toad
michigan
You guys running the NKG plugs do you have a part number I see there's a couple different ones that will work?
[Re: dvw]
#2382968
10/06/17 02:24 PM
10/06/17 02:24 PM
Posts: 368 michigan
turbo toad
michigan
NGK 5671 -10 is what I'd start with. Doug Thanks Doug is 10 the heat range? On my old e85 turbo setup the slant liked a 7 heat range plug gapped at .028.
[Re: turbo toad]
#2383055
10/06/17 05:37 PM
10/06/17 05:37 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
NGK and Moroso Ultra 40 wires.
[Re: FastmOp]
#2383325
10/07/17 10:43 AM
10/07/17 10:43 AM
Posts: 368 michigan
turbo toad
michigan
David if you ever come back up north me and the wife have a place for you to stay.
[Re: turbo toad]
#2383328
10/07/17 10:56 AM
10/07/17 10:56 AM
Posts: 52,972 Romeo MI
MR_P_BODY
David if you ever come back up north me and the wife have a place for you to stay. Where are you at in Mich
[Re: turbo toad]
#2383341
10/07/17 11:29 AM
10/07/17 11:29 AM
Posts: 368 michigan
turbo toad
michigan
Anyone happen to have the part number for a WIX oil filter I need to pick a couple up thus week. I cant figure out how to post pics using my photebucket account and I cant resize them via my phone.
