Plugs and plug wire recommendations needed #2382465
10/05/17 03:13 PM
10/05/17 03:13 PM
michigan
turbo toad Offline OP
michigan
Its been awhile since I posted but I'm buttoning up my build and I'm to the point where I'm in need of some info on plugs and wires for my junk.
HEI style dizzy
E85 fuel
Indy 440-1 heads
10-15 psi of boost
Big block low deck in a abody
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382650
10/05/17 08:52 PM
10/05/17 08:52 PM
NGK & firecore
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382656
10/05/17 08:59 PM
10/05/17 08:59 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Ngk and firecore here
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382675
10/05/17 09:26 PM
10/05/17 09:26 PM
an8sec70cuda Offline
NGK plugs and either MSD or Taylor for wires.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382677
10/05/17 09:31 PM
10/05/17 09:31 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
NGK plugs and I got some purple Taylor wires.
[image][/image]
Re: Plugs and plug wire recommendations needed [Re: sgcuda] #2382760
10/05/17 11:46 PM
10/05/17 11:46 PM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Autolite plugs and MSD wires twocents
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382842
10/06/17 05:16 AM
10/06/17 05:16 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Tell em what it is 😆
I know your about to fire it. You better post vids 👌
I wish I was closer so I could help.
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382850
10/06/17 08:17 AM
10/06/17 08:17 AM
michigan
michigan
Thanks guys
Fastmop ill get some video and post it up.
There's only a couple minor things left to do and I hope to have things buttoned up minis the turbos plumbing By next week.
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382903
10/06/17 11:49 AM
10/06/17 11:49 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
NGK and Taylor Spiro pro wires.last set I had on for at least 15 years.Thats with headers on a BB.Run them on everything.Replaced mine because they looked nasty but still worked like new.Rocky
Chrysler Firepower
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382916
10/06/17 12:14 PM
10/06/17 12:14 PM
michigan
michigan
You guys running the NKG plugs do you have a part number I see there's a couple different ones that will work?
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382931
10/06/17 01:05 PM
10/06/17 01:05 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
NGK 5671 -10 is what I'd start with.
Doug
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382942
10/06/17 01:26 PM
10/06/17 01:26 PM
IL
Dart451 Offline
Dart451  Offline
IL
NGK and Firecore, going to order another set of custom wires today.
Re: Plugs and plug wire recommendations needed [Re: dvw] #2382968
10/06/17 02:24 PM
10/06/17 02:24 PM
michigan
michigan
Doug
Thanks Doug is 10 the heat range? On my old e85 turbo setup the slant liked a 7 heat range plug gapped at .028.
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2382977
10/06/17 02:51 PM
10/06/17 02:51 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I run a R5671A-9. Stock number 5238
I run a tighter gap
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383025
10/06/17 04:23 PM
10/06/17 04:23 PM
IL
Dart451 Offline
Dart451  Offline
IL
Ordered my custom length firecore wires at 11:55 got a shipping notice email at 1:01 have to like that turn around up
12 Years ago I dynoed a new set of firecore wires vs a new set of msd. Dyno operator said I was wasting my time until he seen the results got over 5 hp from nothing but the wire change. This was on a 735 hp pump gas engine.
Been my first choice ever since. beer
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383055
10/06/17 05:37 PM
10/06/17 05:37 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
NGK and Moroso Ultra 40 wires.
Nautilus Racing-
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383089
10/06/17 07:24 PM
10/06/17 07:24 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I run NGK or Autolite plugs and use Firecore plug wires which are great. I have also used Taylor wires which worked good for me. Ron
Re: Plugs and plug wire recommendations needed [Re: FastmOp] #2383325
10/07/17 10:43 AM
10/07/17 10:43 AM
michigan
michigan
David if you ever come back up north me and the wife have a place for you to stay.
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383328
10/07/17 10:56 AM
10/07/17 10:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Where are you at in Mich
wave
Re: Plugs and plug wire recommendations needed [Re: turbo toad] #2383341
10/07/17 11:29 AM
10/07/17 11:29 AM
michigan
michigan
Anyone happen to have the part number for a WIX oil filter I need to pick a couple up thus week.
I cant figure out how to post pics using my photebucket account and I cant resize them via my phone.
