Throttle Stop Racers #238214
02/27/09 07:38 PM
02/27/09 07:38 PM
Port Orchard, Washington
Bad Boy Offline OP
Bad Boy  Offline OP
How much mile per hour can you scrub off using a throttle stop down track? The car goes 9.22 all out at 142. I need to get it below 135 so that I don't need a license to drive it. Can you scrub off 8 MPH using the throttle stop?
Re: Throttle Stop Racers [Re: Bad Boy] #238215
02/27/09 09:02 PM
02/27/09 09:02 PM
Is that a track requirement?
You can use a stop to scrub off the mph. Why not just put a chip in it?
Re: Throttle Stop Racers [Re: ] #238216
02/27/09 11:16 PM
02/27/09 11:16 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I assume you're talking about a timer controlled in-line or under the carb style stop. I had to kill about .7 or .8 and did it all in the first 2 seconds of the run. Only lost 1 or 2 MPH. You'll have to do it in the middle of the track. If you get too far down track, you won't be able to get the ET into the 10s. Consistency goes away when you run the stop too far down track also. I would recommend a 4 stage timer (drop it once early to kill ET, drop it again at 1000' to kill MPH. Makes it tough to fender race you too) OR some type of stop or bolt on the carb/throttle linkage.
Re: Throttle Stop Racers [Re: ] #238217
02/27/09 11:24 PM
02/27/09 11:24 PM
Bad Boy Offline OP
Bad Boy  Offline OP
The throttle stop and the delay box are already in the car. No it"s not a track requirement it's an NHRA requirement. They slid in a new disclaimer at the front of Super Pro (section 4 A) of the 2009 rule book which is on Page 58 and it states " Any vehicle except ET motorcycle running faster than 135 MPH must meet the minimum requirement for 9.99 second vehicles "including driver credentials and protective clothing" That last part is the new addition. So that means that all of you Super Street guys that run at 10.90 and 145 MPH, but don't have a license will need one now.
Re: Throttle Stop Racers [Re: Bad Boy] #238218
02/27/09 11:42 PM
02/27/09 11:42 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Most of the newer boxes have 4 stage timers.
Re: Throttle Stop Racers [Re: Bad Boy] #238219
02/28/09 09:42 AM
02/28/09 09:42 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
9.99 you need cert and a license .
T/S will kill et not alot of MPH
135 MPH will be interesting with the street nitrous cars and s/s car.
Whats the issue
don
2009 418" build dan smith built new 9.96 131.82 6.23 108 1.30 60 foot best to date 9/15/09 8in 727 430 dana 2860 lb 3040 lb w driver
Re: Throttle Stop Racers [Re: 10 o to go] #238220
02/28/09 10:49 AM
02/28/09 10:49 AM
San Diego, CA
brktracr Offline
super street
brktracr  Offline
super street
San Diego, CA
You can throttle stop it on the top end. Know a few dragsters and door cars that are doing that. We run 1/8 mile and one Camaro capable of running 5.70's, throttles stops it off the line then again at the top end to run 6.30's at 110mph. So it is possible, depends on how you set the stop. My
1.298 60 ft 6.001 1/8 mile 114 mph 9.52 1/4 mile 140.87 mph @ 3110 lbs
Re: Throttle Stop Racers [Re: Bad Boy] #238221
02/28/09 03:14 PM
02/28/09 03:14 PM
Arizona
Chris'sBarracuda Offline
Arizona
That rule has been in effect for S/ST for several years now.
No news there.
Chris..
Re: Throttle Stop Racers [Re: Chris'sBarracuda] #238222
02/28/09 04:38 PM
02/28/09 04:38 PM
Wisconsin
Garceau Offline
Garceau  Offline
Wisconsin
Many tracks up here wont allow "down track throttle stops". But thats the only way to kill some MPH without killing too much ET.
However having played with my very consistent daytona, throttle stopping it on the top was a little less consistent. Because your going at a high rate of speed, and then slowing it down any amounts of wind really effected it differently.
If not too much work, may be a better route to regear, or recam the thing. Taking some cam out of it, wont hurt consistency and will help everything live much longer.
Just a thought.
Re: Throttle Stop Racers [Re: Garceau] #238223
02/28/09 09:32 PM
02/28/09 09:32 PM
Bad Boy Offline OP
Bad Boy  Offline OP
Thanks for the replies guys. I'll have to play with it while I go through the process of getting a license. Hell I don't even know if this old body will pass a physical for a license.
Re: Throttle Stop Racers [Re: Bad Boy] #238224
03/01/09 09:46 AM
03/01/09 09:46 AM
St. Louis Mo.
10 o to go Offline
"Happy Don"
10 o to go  Offline
"Happy Don"
St. Louis Mo.
i just got my pysical last week took the NHRA papers to DOC did the examination .Looks like i passed
download forms from nhra site.
Now to send to nhra and wait.
don
Re: Throttle Stop Racers [Re: 10 o to go] #238225
03/01/09 10:47 AM
03/01/09 10:47 AM
Way North Illinois
JandJ_Racing Offline
Way North Illinois
How about box settings? How soon do you go on the stop? 4 to 5 tenths after letting the brake go?
