Re: Throttle Stop Racers
[Re: Bad Boy]
#238215
02/27/09 09:02 PM
02/27/09 09:02 PM
Is that a track requirement?
You can use a stop to scrub off the mph. Why not just put a chip in it?
[Re: ]
#238216
02/27/09 11:16 PM
02/27/09 11:16 PM
Posts: 11,497 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I assume you're talking about a timer controlled in-line or under the carb style stop. I had to kill about .7 or .8 and did it all in the first 2 seconds of the run. Only lost 1 or 2 MPH. You'll have to do it in the middle of the track. If you get too far down track, you won't be able to get the ET into the 10s. Consistency goes away when you run the stop too far down track also. I would recommend a 4 stage timer (drop it once early to kill ET, drop it again at 1000' to kill MPH. Makes it tough to fender race you too) OR some type of stop or bolt on the carb/throttle linkage.
[Re: Bad Boy]
#238218
02/27/09 11:42 PM
02/27/09 11:42 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Most of the newer boxes have 4 stage timers.
[Re: Bad Boy]
#238221
02/28/09 03:14 PM
02/28/09 03:14 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
The throttle stop and the delay box are already in the car. No it"s not a track requirement it's an NHRA requirement. They slid in a new disclaimer at the front of Super Pro (section 4 A) of the 2009 rule book which is on Page 58 and it states " Any vehicle except ET motorcycle running faster than 135 MPH must meet the minimum requirement for 9.99 second vehicles "including driver credentials and protective clothing" That last part is the new addition. So that means that all of you Super Street guys that run at 10.90 and 145 MPH, but don't have a license will need one now.
That rule has been in effect for S/ST for several years now. No news there.
Chris..
[Re: Bad Boy]
#238224
03/01/09 09:46 AM
03/01/09 09:46 AM
Posts: 1,489 St. Louis Mo.
10 o to go
"Happy Don"
"Happy Don"
St. Louis Mo.
i just got my pysical last week took the NHRA papers to DOC did the examination .Looks like i passed download forms from nhra site. Now to send to nhra and wait. don
2009 418" build dan smith built
new 9.96 131.82
6.23 108
1.30 60 foot
best to date 9/15/09
8in 727 430 dana 2860 lb 3040 lb w driver
