340 Six Pack Carb part ID #2382075
10/04/17 09:58 PM
10/04/17 09:58 PM
Mechanicsburg, PA
LemonTwiist Offline OP
Mechanicsburg, PA
The center carb will not fill the bowl with gas. Both outboard carbs are getting fuel. I can manually fill the bowl through the sight screw and is runs until the gas is gone, then stops. At first I thought the float was stuck so I took the carb apart and this part fell out of the bowl when I opened it. I don't recognize it and I don't know if it belongs in there. It is plastic, but I don't see anything like it in the rebuild kit or the diagram. the float moves freely so it's not the float. Ant ideas as to what it is and where it goes and what it does?
Re: 340 Six Pack Carb part ID [Re: LemonTwiist] #2382101
10/04/17 10:39 PM
10/04/17 10:39 PM
Spokane Washington
ScottSmith_Harms Online content
Mr Wizzard
ScottSmith_Harms  Online Content
Mr Wizzard
Spokane Washington
Looks like a bowl vent cover, originals were metal, some replacements are plastic.
Re: 340 Six Pack Carb part ID [Re: ScottSmith_Harms] #2382116
10/04/17 10:59 PM
10/04/17 10:59 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
This is an old picture. Gasket goes over it.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 340 Six Pack Carb part ID [Re: ScottSmith_Harms] #2382164
10/04/17 11:49 PM
10/04/17 11:49 PM
Mechanicsburg, PA
Mechanicsburg, PA
OK Thanks I see now where it goes
Re: 340 Six Pack Carb part ID [Re: LemonTwiist] #2382213
10/05/17 01:11 AM
10/05/17 01:11 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I would pull the needle seat assy, chances are some crap has gotten into the seat, perhaps fine rust particles, just enough to hold the seat closed and not allow the bowl to fill...seats either get stuck open allowing flood conditions or seized close causing fuel starvation
Re: 340 Six Pack Carb part ID [Re: LemonTwiist] #2382729
10/05/17 10:53 PM
10/05/17 10:53 PM
Mechanicsburg, PA
Mechanicsburg, PA
Thanks Yes I did that and the seat works well I think that is what originally happened. It was stuck shut. Readjusted the float and will also do a complete gasket change and insert a filter in the inlet
Re: 340 Six Pack Carb part ID [Re: LemonTwiist] #2382763
10/05/17 11:49 PM
10/05/17 11:49 PM
70sixpkrt Offline
70sixpkrt  Offline
Did it originally have a filter in the inlet? I've seen some with no filter.
4-speed
3:54 Dana
