360 magnum motor retro fit in 72 cuda #2382089
10/04/17 10:24 PM
10/04/17 10:24 PM
northeast ohio
hulmule Offline OP
hulmule  Offline OP
northeast ohio
Well doing a father / son project. As we are going thru the 72 Cuda and doing a resto, here's some questions.
To rebuild a 340 motor that came with the car (NOM)cost are pretty high. Needs bored , head work etc. So I picked up a 360 magnum from a 2002 Dodge van with 84k on it. Drove it home from over an hour away and ran great with no problems and great oil pressure. Questions. 1)what motor mounts can I use? 2)Will the computer work? I hear 2002 computers controlled motors only? what other issues am I going to run into by doing swap? Been reading articles on how they make good horse power.Any info on 360 motors and retro into the cuda would be great. Oh yes the car was an original 340 -3 speed car, going to do a 4 speed unless I can research a 5-6 speed that fits. thanks
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: 360 magnum motor retro fit in 72 cuda [Re: hulmule] #2382140
10/04/17 11:25 PM
10/04/17 11:25 PM
I would get a magnum 4bbl intake/OE dist/low psi elec fuel pump or the Hughes cam extension to use an LA timing cover/mech fuel pump. 5.9 mag balance is different than an LA 360. the block ears on the DR side might need a slight bit of spacing with washers to use the 340 mts, hold the mts up to the block to see what you need there.
