Holley Fuel Inlet Fitting #2382041
10/04/17 08:10 PM
10/04/17 08:10 PM
South San Francisco, Ca
70sixpkrt Offline OP
I need to get a new Holley fuel inlet fitting and metal gasket for a 4365 six pack carb because of a leak. Are they the same for any Holley carb? Any part #?
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Holley Fuel Inlet Fitting [Re: 70sixpkrt] #2382142
10/04/17 11:25 PM
10/04/17 11:25 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Item Details:
FUEL INLET FITTING - Holley six pack carburetor, 5/16 inlet size
Years: 69-71
Our Part Number: B3892
Price: $8.95
1-800-872-2446
Yeah, it's hopped up to over 160...
Re: Holley Fuel Inlet Fitting [Re: 70sixpkrt] #2382154
10/04/17 11:35 PM
10/04/17 11:35 PM
Thank you. Is that Holley's part # ? I'm going to Summitt Racing in Reno this weekend to buy some parts and figure to get that also.
4-speed
3:54 Dana
Re: Holley Fuel Inlet Fitting [Re: 70sixpkrt] #2382328
10/05/17 10:50 AM
10/05/17 10:50 AM
Phila. Pa.
Mattax Offline
Mattax  Offline
Phila. Pa.
Make sure it comes with, or get some spare, gaskets. It's a black coated thin metal gasket - goes between the fitting and the bowl.
Re: Holley Fuel Inlet Fitting [Re: 70sixpkrt] #2382356
10/05/17 12:20 PM
10/05/17 12:20 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
Just bought the same thing from Holley, it came with the thin metal gasket you mentioned and another smaller cork-like gasket???
Any idea what that's for?
I had a slight leak from my rear two barrel at that point, couldn't really tell exactly which fitting was leaking it was so little.
I'm waiting on the 4 fuel lines in the kit they sell and replacing the whole pile of 50 year-old connections.
The rear carb. had a nylon gasket instead of the metal one so I suspect that may be the culprit.
We'll see....
P.S. Holley's part # for the 5/16" is 26-27
P.P.S. Just spoke w/Holley about the smaller gasket, it's for the filter that came originally in there. Forgot about that!!
Joe
Re: Holley Fuel Inlet Fitting [Re: jlatessa] #2382374
10/05/17 12:59 PM
10/05/17 12:59 PM
We'll see....
Joe
thumbs
Thanks for the info.
4-speed
3:54 Dana
