Lakewood Bellhousing?
#238019
02/27/09 04:21 PM
02/27/09 04:21 PM
Posts: 505 Northampton Pa
65 NSS 500
Northampton Pa
I am looking to convert my car to a 4sp and am trying to find a used lakewood Blow proof Bell. I see there is a starter attachment or option. Am I correct that something extra is needed to mountthe starter . Also how critical are the offset pins. I am trying to be thrifty but dont want someones junk or a big problem.?
1965 Coronet 500
340 40+ Passon 4sp
12.90 2.6 60' street tires
Re: Lakewood Bellhousing?
[Re: 65 NSS 500]
#238020
02/27/09 05:15 PM
02/27/09 05:15 PM
The Lakewood housing works fine and has a starter mounting like a standard stock bell housing..What tranny are you running??
[Re: 65 NSS 500]
#238021
02/27/09 05:19 PM
02/27/09 05:19 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
I am looking to convert my car to a 4sp and am trying to find a used lakewood Blow proof Bell. I see there is a starter attachment or option. Am I correct that something extra is needed to mount the starter . Also how critical are the offset pins. I am trying to be thrifty but dont want someones junk or a big problem.?
The offset kit for the starter depends on the size flywheel , I think you need it to run the 130 tooth wheel .
By offset pins do you mean the dowels pins in the block ??? If so SUPER CRITICAL , the lakewood housing MUST be dialed in .
[Re: 65 NSS 500]
#238023
02/27/09 07:12 PM
02/27/09 07:12 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
If we are still talking about the small block bellhousing it only has a stater mount for a 130 tooth wheel so you don't need any of the starter mount kits that big block bells use.What crank flange do you have? A few of us Moparts guys designed and built a rock solid tool for checking bellhousing alignment.It's for a six bolt crank and could send it to you for some short term use.My block will be back soon so I will need it too.Once you determine what dowel you need order them from RobbMc he belongs to this web board and his dowels are actually made for a Mopar not a Ford the the ones Lakewood sells. Let me know Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#238024
02/28/09 07:19 PM
02/28/09 07:19 PM
65 NSS 500
Northampton Pa
I am not sure what flange I have a 71 340 I will have to check, Thanks for the tool offer I will have see and go from there
1965 Coronet 500
340 40+ Passon 4sp
[Re: 65 NSS 500]
#238025
02/28/09 09:18 PM
02/28/09 09:18 PM
fourgearsavoy
Rittman Ohio
Last week there was a brand new small block Lakewood bell on the return table at Summit for $200.00.If you want it let me know and I will snag it for you.All you would have to get is the block plate. Gus
[Re: fourgearsavoy]
#238026
02/28/09 10:33 PM
02/28/09 10:33 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Problem is a block plate is almost a 100 buck.So the cost would be about the same.I got a BB one free and needed the plate.Luckily I bought another good used bell and plate for 80 bucks.My cost for a plate like 8 years ago was 80 bucks.Rocky
Chrysler Firepower
