Auto Trans Vent for 4x4 Relocation #2380055
10/01/17 05:22 PM
10/01/17 05:22 PM
Ca
76440 Offline OP
76440  Offline OP
Ca
Relocated the vent on a 1992 618 diesel 4x4 trans. Plugged the stock vent hole on the pump behind the torque converter. Drilled and tapped the trans for 1/4"npt about 1.25" towards the passenger side of the top of the trans and approximately 11.875" from the rear flange of the main case...where the overdrive unit bolts to the main case. Installed pipe fittng with adapter and a hose to the engine compartment.
Reinstalled the unit and after it ran a short while I am getting major leak behind the torque converter. Front seal is new along with the bushing in the pump.
Did I drill and tap the new vent fittng in the wrong spot? If so where should I put it? Not much room at all behind the diesel torque converter to run it in the stock location and drill through the bellhousing to run the vent line.
Re: Auto Trans Vent for 4x4 Relocation [Re: 76440] #2380072
10/01/17 05:54 PM
10/01/17 05:54 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Why did you choose that particular spot to drill for the vent? I don't have a 618 case to measure but it appears you have drilled into the bellhousing area in front of the pump. With the original vent plugged you effectively have no vent at all.
Re: Auto Trans Vent for 4x4 Relocation [Re: John_Kunkel] #2380085
10/01/17 06:11 PM
10/01/17 06:11 PM
Ca
76440 Offline OP
76440  Offline OP
Ca
I saw on some 4x4 sites that people were plugging the stock vent in the pump and drilling one just behind the pump. Here is a link to the thread.
http://www.binderplanet.com/forums/index.php?threads/727-tranny-vent.55125/
I offset to the passenger side slightly. Positive I am behind the pump and inside the trans. I have another 618 trans case that is empty and I can measure.
Re: Auto Trans Vent for 4x4 Relocation [Re: 76440] #2380146
10/01/17 07:33 PM
10/01/17 07:33 PM
Ca
76440 Offline OP
76440  Offline OP
Ca
Edit: realized in my original post I wrote 11.875 inches from the rear overdrive flange. The hole is actually 7.85" from the rear flange where the overdrive bolts on.
