Re: 1968 - 1969 4 speed shifter issues
[Re: Dave Hall]
#2379437
09/30/17 05:39 PM
09/30/17 05:39 PM
Posts: 21,430 It's a dry heat
gtx6970
It's a dry heat
If the pic is the shifter in neutral, I would imagine that 1st is hitting as well. The picture is showing me that the bracket is twisted toward the front of the car and it is not level from the bend to the shifter. It looks as if you could use this bracket with some cut and fab modification. Otherwise that can't be the right bracket. Its in neutral as shown I think in the 1-2 shifter gate. I can get it in 1st or 2nd but it rubs the console. Reverse is out of the question without some serious distorting the console Going to call Brewers Monday morning and maybe pick Waynes brain if I can.
[Re: gtx6970]
#2381257
10/03/17 02:08 PM
10/03/17 02:08 PM
Posts: 75,012 U.S.S.A.
JohnRR
U.S.S.A.
Bill, there is only one bracket on that holds the shifter on for a Hurst shifter , console or non console it's the same.
68 for the most part used the inland shifter , I don't know if there is a difference in consoles for hurst vs. inland ?
Is that an original 4speed console or an auto console that was modified?
On a side note the correct lower boot you need is available I believe.
[Re: gtx6970]
#2382922
10/06/17 12:32 PM
10/06/17 12:32 PM
JohnRR
U.S.S.A.
Inland shifter brackets would need to have a hole in it to work with a Hurst shiters or you won't be able to get it into reverse , so ??? there is a thread about this bracket posted by Barry Washington just recently , it looked like it might move the shifter up some ?
