Camber Spacers from Mancini-- thoughs/opinions? #2377707
09/27/17 01:54 PM
09/27/17 01:54 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
-2* of camber sounds just about right. This looks like a darned easy way to get some.
Any concerns here? Has anyone seen these in person? Are they just 3mm or so thick washers?
http://www.manciniracing.com/maracaspkit.html
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2377720
09/27/17 02:22 PM
09/27/17 02:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Not sure where having 2 or more degrees of camber is a needful thing.
Caster, sure, camber? Seems a good way to tear up a set of tires.
Don't be the exception.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2377794
09/27/17 04:43 PM
09/27/17 04:43 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
Yes. Excessive camber definitely eats tires but contact patch under cornering load is the name of the game...particularly for the folks in this forum.
Basically, negative camber compensates for the inevitable geometry changes while cornering and keeps more rubber on the road/track.
-2* is relatively mild for a dedicated handling set up. I suspect that any negative camber that we can get up front is extra valuable since the only way to get that in the rear is not going to help the longevity of your drivetrain. laugh
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2377824
09/27/17 05:39 PM
09/27/17 05:39 PM
Northern California
lilcuda Offline
lilcuda  Offline
Northern California
Those are made by AR Engineering. The Red Brick has them. If you want handling and don't care about tire wear so much, go for it.
'67 is an abbreviation of 1967
67' is an abbreviation of 67 feet
They are not interchangeable.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: lilcuda] #2377904
09/27/17 08:06 PM
09/27/17 08:06 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
Just go to your local hardware store and get some grade 8 washers. Not to take $$ out of Andy's pocket, so buy his excellent book with the cash you save.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: lilcuda] #2377985
09/27/17 10:09 PM
09/27/17 10:09 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
Thanks.
I have heard people mention the Red Brick many times...this is somehow related to (or inspired by) the Green Brick Valiant, I assume?
As for tire wear; I don't know about you guys but if my Dart gets even 800 miles in a year, it would be reason to celebrate. Tire wear isn't a huge concern for me and probably not for many of us in this section of Moparts! cool In any case,I'm rolling on fresh BFG Radial T/A no-season compound radials...my last set were 17 years old before I got rid of them. Bring on the wear!
Yes, these are low-grip tires but I'd also hope that folks here also know that grip and handling are not the same thing. Besides, those tires need as reliable of a contact patch as we can give them.
Just for some reference, I have 200 treadwear 285/35/19s on the front of my 2011 Mustang GT. Using the (questionable) Eibach Camber Bolts and GT500 strut mounts rotated 180*, I was able to get just over -1.5* camber...and I've been wailing through corners for almost 12,000 miles on those soft compound tires and that alignment. While they're showing some signs of wearing on the inside shoulder...they're fine for another few thousand. Not bad for that class of tire. I'm not worried about the BFGs.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2378052
09/28/17 12:23 AM
09/28/17 12:23 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
I have wondered about these spacers too. It seems that using these (Or something slightly thinner) along with Moog K-7103 offset UCA bushings would allow you to have some acceptable amount of negative camber and a bunch more caster. Since the alignment cams allow such a little range of adjustment, little tricks like these can help fine tune the settings while allowing the car to maintain OEM durability of stock based parts.
Being cheap always helps as well.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: Skeptic] #2378104
09/28/17 01:56 AM
09/28/17 01:56 AM
AndyF Online content
AndyF  Online Content
We tried washers and the OD is too large so I had thick spacers with the correct OD made. We used them on Tim's Valiant and they worked so I just had some extras made and put them on the shelf. I only sell a few sets a year so it isn't much of a money maker but they don't take up much space on the shelf and they don't go bad over time so I keep them in the product line.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2378107
09/28/17 02:02 AM
09/28/17 02:02 AM
This is what Tim was after.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2378154
09/28/17 09:04 AM
09/28/17 09:04 AM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
Thanks, guys!
Did some reading up on the Red Brick build and I do believe that I've seen it around on the forums, etc...but it was great to learn some of the details. That car is an inspiration!
I'm very grateful for the pioneers in our hobby who figure stuff out and share their knowledge. Supporting them by buying their books and parts that they develop seems like a good way to say thanks.
I will definitely order up a set.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2378179
09/28/17 10:58 AM
09/28/17 10:58 AM
Mountain View, CA
68rrunner Offline
68rrunner  Offline
Mountain View, CA
And FWIW, Camber on the new Scatpack, SRT and HellKitty Chargers and Challengers specs between 1-5 and 2.5* of Camber and 10* of Caster on the front and a degree or so on the rear.
So 2* on a older Mopar will not kill your tires in 50 miles.
Never a shortage of bad info on this forum. SMH
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: 68rrunner] #2378181
09/28/17 11:04 AM
09/28/17 11:04 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Never a shortage of wild, over the top falsehoods too.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: 68rrunner] #2378230
09/28/17 12:47 PM
09/28/17 12:47 PM
Connecticut, USA
MRGTX Offline OP
MRGTX  Offline OP
Connecticut, USA
This lines up with what I've heard. It also goes without saying that a Hellcat is HELL on tires (front and rear) thanks to the weight and power levels so if your tires are holding up, this is a valuable data point.
Guys who track S197 Mustangs like mine often install camber plates to get them up to -3* IMO, that seems to be on the high end of what you'd want on a daily driver but so long as you know what you're getting yourself into, it's great.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2378829
09/29/17 01:42 PM
09/29/17 01:42 PM
Yeah the camber spacers are a crude version of the Mustang camber plates. When you're working with 50 year old suspension designs you just have to do what you have to do.
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: MRGTX] #2378899
09/29/17 03:30 PM
09/29/17 03:30 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Some people run thin wheel spacers when an "off the shelf" wheel doesn't quite fit. I always thought that these spacers would be an easy way to get a little extra clearance without having to use a wheel spacer.
Instead of an 1/8" wheel spacer, you could use the camber spacers(move bottom of tire out) and adjustable UCAs.(to move the top of the tire out)
Re: Camber Spacers from Mancini-- thoughs/opinions? [Re: burdar] #2380404
10/02/17 02:09 AM
10/02/17 02:09 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
What does that do to your kingpin angle?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
