Camber Spacers from Mancini-- thoughs/opinions?
#2377707
09/27/17 01:54 PM
09/27/17 01:54 PM
Posts: 111 Connecticut, USA
MRGTX
Connecticut, USA
-2* of camber sounds just about right. This looks like a darned easy way to get some. Any concerns here? Has anyone seen these in person? Are they just 3mm or so thick washers? http://www.manciniracing.com/maracaspkit.html
Re: Camber Spacers from Mancini-- thoughs/opinions?
[Re: MRGTX]
#2377720
09/27/17 02:22 PM
09/27/17 02:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not sure where having 2 or more degrees of camber is a needful thing.
Caster, sure, camber? Seems a good way to tear up a set of tires.
[Re: MRGTX]
#2377794
09/27/17 04:43 PM
09/27/17 04:43 PM
MRGTX
Connecticut, USA
Yes. Excessive camber definitely eats tires but contact patch under cornering load is the name of the game...particularly for the folks in this forum. Basically, negative camber compensates for the inevitable geometry changes while cornering and keeps more rubber on the road/track. -2* is relatively mild for a dedicated handling set up. I suspect that any negative camber that we can get up front is extra valuable since the only way to get that in the rear is not going to help the longevity of your drivetrain.
[Re: MRGTX]
#2377824
09/27/17 05:39 PM
09/27/17 05:39 PM
Posts: 701 Northern California
lilcuda
Northern California
Those are made by AR Engineering. The Red Brick has them. If you want handling and don't care about tire wear so much, go for it.
'67 is an abbreviation of 1967 67' is an abbreviation of 67 feet They are not interchangeable.
[Re: lilcuda]
#2377985
09/27/17 10:09 PM
09/27/17 10:09 PM
MRGTX
Connecticut, USA
Those are made by AR Engineering. The Red Brick has them. If you want handling and don't care about tire wear so much, go for it. Thanks. I have heard people mention the Red Brick many times...this is somehow related to (or inspired by) the Green Brick Valiant, I assume? As for tire wear; I don't know about you guys but if my Dart gets even 800 miles in a year, it would be reason to celebrate. Tire wear isn't a huge concern for me and probably not for many of us in this section of Moparts! In any case,I'm rolling on fresh BFG Radial T/A no-season compound radials...my last set were 17 years old before I got rid of them. Bring on the wear! Yes, these are low-grip tires but I'd also hope that folks here also know that grip and handling are not the same thing. Besides, those tires need as reliable of a contact patch as we can give them. Just for some reference, I have 200 treadwear 285/35/19s on the front of my 2011 Mustang GT. Using the (questionable) Eibach Camber Bolts and GT500 strut mounts rotated 180*, I was able to get just over -1.5* camber...and I've been wailing through corners for almost 12,000 miles on those soft compound tires and that alignment. While they're showing some signs of wearing on the inside shoulder...they're fine for another few thousand. Not bad for that class of tire. I'm not worried about the BFGs.
[Re: Skeptic]
#2378104
09/28/17 01:56 AM
09/28/17 01:56 AM
Posts: 31,044 Oregon
AndyF
Just go to your local hardware store and get some grade 8 washers. Not to take $$ out of Andy's pocket, so buy his excellent book with the cash you save. We tried washers and the OD is too large so I had thick spacers with the correct OD made. We used them on Tim's Valiant and they worked so I just had some extras made and put them on the shelf. I only sell a few sets a year so it isn't much of a money maker but they don't take up much space on the shelf and they don't go bad over time so I keep them in the product line.
[Re: 68rrunner]
#2378181
09/28/17 11:04 AM
09/28/17 11:04 AM
Supercuda
About to go away
About to go away
up yours
And FWIW, Camber on the new Scatpack, SRT and HellKitty Chargers and Challengers specs between 1-5 and 2.5* of Camber and 10* of Caster on the front and a degree or so on the rear. So 2* on a older Mopar will not kill your tires in 50 miles.
Never a shortage of bad info on this forum. SMH Never a shortage of wild, over the top falsehoods too.
[Re: 68rrunner]
#2378230
09/28/17 12:47 PM
09/28/17 12:47 PM
MRGTX
Connecticut, USA
Never a shortage of bad info on this forum. SMH This lines up with what I've heard. It also goes without saying that a Hellcat is HELL on tires (front and rear) thanks to the weight and power levels so if your tires are holding up, this is a valuable data point. Guys who track S197 Mustangs like mine often install camber plates to get them up to -3* IMO, that seems to be on the high end of what you'd want on a daily driver but so long as you know what you're getting yourself into, it's great.
[Re: burdar]
#2380404
10/02/17 02:09 AM
10/02/17 02:09 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
What does that do to your kingpin angle? Some people run thin wheel spacers when an "off the shelf" wheel doesn't quite fit. I always thought that these spacers would be an easy way to get a little extra clearance without having to use a wheel spacer.
Instead of an 1/8" wheel spacer, you could use the camber spacers(move bottom of tire out) and adjustable UCAs.(to move the top of the tire out)
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
