Re: Missing vin tag but has data plate
[Re: bigblockbryan]
#2377211
09/26/17 03:31 PM
09/26/17 03:31 PM
Posts: 17,862 albany ny
05dakota
albany ny
state issued vin is only legal optuin
5549 post on old board
[Re: bigblockbryan]
#2377238
09/26/17 05:03 PM
09/26/17 05:03 PM
Posts: 4,748 Florida
BDW
If you have title and all numbers on car match that title, check with DataTags.com
And do not post VIN here
[Re: Supercuda]
#2377268
09/26/17 06:12 PM
09/26/17 06:12 PM
Posts: 29,654 Hamtramck, PA
Alaskan_TA
Fluffy Balladeer
Fluffy Balladeer
Hamtramck, PA
Nine days later, a Colorado man, whose name is being withheld pending further investigation, made a counterfeit VIN plate bearing BS23RB345378 and charged Papadopoulos $395. Quote above from the the Hemmings Motor News article at https://www.hemmings.com/magazine/mus/2006/07/Steal-of-a-Lifetime-/1301462.htmlThe 'Colorado man' is mentioned by name in the actual court case & it is a matter of public record. He did admit to making a counterfeit VIN tag to the investigating officer & there are many other interesting details in the criminal court case also, including another fake VIN. So the best and legal advice is to check with your local motor vehicle agency for a state issued VIN.
[Re: bigblockbryan]
#2377276
09/26/17 06:36 PM
09/26/17 06:36 PM
Posts: 2,080 CA
crackedback
CA
The problem with hemi cuda tag was it was NEVER a legit vin. That's the criminal intent to swap it from an N to a R code engine.
Send you E body dash in with tag still attached for refurbishing and see if it comes back... LOL Know a couple of people that have had that occur.
JMO, It's not nefarious to get a reproduction VIN tag for a car that one was stolen off of or lost during resto. There is zero criminal intent to defraud anyone.
There are plenty of things that happen that DO defraud, VIN swap, etc.
Have at it.
[Re: Alaskan_TA]
#2377307
09/26/17 07:57 PM
09/26/17 07:57 PM
BDW
The court case clearly mentions in all caps "FALSELY MAKE".
'Correct' number or not, not legal to remake a VIN tag. Absolutely not true, as mentioned, you need "criminal intent" If OP has title and car that matches said title, perfectly legal to get VIN made.
[Re: BDW]
#2377312
09/26/17 08:17 PM
09/26/17 08:17 PM
Posts: 18,157 Mass
DAYCLONA
Mass
'Correct' number or not, not legal to remake a VIN tag. Absolutely not true, as mentioned, you need "criminal intent" If OP has title and car that matches said title, perfectly legal to get VIN made. Exactly, done all the time, if you have all the proper docs, a repro VIN tag can be made, it's just a piece of tin with numbers on it, not some DNA swab some would like you to think it is If the OP has all the docs needed, go to www.datatags.com to "inquire" about having a tag made...otherwise just buy some POS matching A body with a clean tag/title and attach as desired
[Re: bigblockbryan]
#2377516
09/27/17 01:32 AM
09/27/17 01:32 AM
Posts: 214 between the coasts
4mayhemi
between the coasts
I bought a car to restore Having the title is good reassurance, but then again I've known of places where titles can magically be made to appear. Before this really goes down that rabbit hole, I'm curious if you'd share: did you buy it assuming it was easy to get the VIN plate made, or did the seller "assure" you it was easy or not needed so you overlooked it?
[Re: srt]
#2377638
09/27/17 11:51 AM
09/27/17 11:51 AM
Posts: 18,157 Mass
DAYCLONA
Mass
It would sux to put money into a car to find out it already exists someplace else.
IMHO I wouldn't even bother pursuing the "original" VIN designation once it's gone, reassign it another VIN from a "clean" donor...
[Re: bigblockbryan]
#2377690
09/27/17 01:15 PM
09/27/17 01:15 PM
Posts: 1,954 Blairsden, CA
Triggerfish
Blairsden, CA
Bryan, this is a hot topic with legit opinions & concerns on both sides of the topic. Yrs ago, just before Harry P. got busted for fake tags on his 383 cuda & a coronet convert, he hosed me on a $10k Hemi motor deal. Luckily, a few yrs later, I ran across a thread on an E body site where Barry Washington & others were the ones who got the guy busted for his fake Hemi Cuda. Long story short, thanks to Barry, I contacted the DA in NY & got 60% of my money back. Point is Harry P had criminal intent & did defraud for way over $100 grand'.
Later, I put the VIN from a 69 Charger RT SE resto I was having done & totally forgot I put the tag in my bro's safe. I sold the almost done project yrs later & couldn't find the VIN tag, so I called DataTags & he wanted a signed authorization letter from the NHP certifying the car was legit & #'s matched VIN AND that the officer appoved of making a tag for resto purposes, which I did. Think it was $250 back then.
Luckily, 6 mos later, my bro found my tag when cleaning out his safe, so its back on the Charger. Sorry for being long winded here, but here's what I'd do in your situation: 3 yrs ago, I got a 64 426 S 4 spd Belvedere, documented but no fender tag. So I contacted Davw Wise at MMC Detroit & had 2 tags made. One that matched Chyrsler Historical's build records one that said, "real deal, kick ass 426 Belvedere" which I put on the car. So, if you're keeping the Duster, why not get a legit state issued VIN tag and one from Wise that says, "Sizzler" and put that one on the dash?
[Re: bigblockbryan]
#2378058
09/28/17 12:40 AM
09/28/17 12:40 AM
Posts: 3,394 cheshire, ct
davesmopars
cheshire, ct
It was ok to do it in mass. I know a guy that the DMV let him have one made. The car was legit. I thinks its up to the state or its about the money.
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
