Pump Gas - Brand vs HP?
#2376549
09/25/17 04:14 PM
09/25/17 04:14 PM
Posts: 5,166 CT
GTX MATT
CT
Anyone see any HP difference between different brands?
Re: Pump Gas - Brand vs HP?
[Re: GTX MATT]
#2376580
09/25/17 04:52 PM
09/25/17 04:52 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I have done 5 drag weeks so my car has had about every brand of pump gas run through it at some point. Any ET variance I have had between tracks has usually been a result of the weather. My combo doesn't seem to care, 91, 93, Ethanol or No Ethanol it runs the same.
68 Barracuda Formula S 340
[Re: GTX MATT]
#2377001
09/26/17 10:28 AM
09/26/17 10:28 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
My best timeslips (9.5s at 140 mph) on pump gas were using no name 93 pump premium from Sparky's fireworks...store right up the road from my house, lol. Runs just as good on that as it does w/ any other brand in it. I really don't think it matters.
[Re: GTX MATT]
#2377098
09/26/17 12:41 PM
09/26/17 12:41 PM
Posts: 1,237 North Central, Indiana
Roughbird72
I have been using Sunoco Ultra 93 and Marathon 93. I my area they are the two brands that have the least amount of alcohol. I have not seen any difference in e.t. between the two.
72 Plymouth Roadrunner 11.08@123.25
[Re: GTX MATT]
#2377306
09/26/17 07:53 PM
09/26/17 07:53 PM
BradH
A couple (few?) decades back, David Vizard did a lot of research on different brands of pump fuel looking to see if there were any differences worth knowing. He did publish some interesting stuff (e.g., some fuels ran better w/ cooled induction systems while others lost less power when the induction was heated) on it. However, it's so out of date that I'd question if anything he found during that effort still applies.
The other thing I can only wonder about, since I'm not in that industry, is if there are more govt. restrictions that reduce the variances in how different oil companies blend their fuels for modern cars. If there is any truth to that, then that fits in w/ some peoples' experiences that brand didn't make a difference.
FWIW, I tried to stay w/ Sunoco and Shell when possible, if only because they both still offer 93 in my area and they're two of the closet stations to my home.
[Re: GTX MATT]
#2377343
09/26/17 09:28 PM
09/26/17 09:28 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I run shell or Texaco 100 low lead in anything that sits or requires performance..Maverik 91 alcohol free in everything else
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: GTX MATT]
#2377446
09/26/17 11:31 PM
09/26/17 11:31 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
Depends on if you are optimizing the time for each fuel. While most pump fuel will likely be similar, there is a difference between E0 and E10. Besides the stoich AFR being different, I have seen some knock benefit from the E10 in Dyno testing. Gained 1-2 degrees spark before detonation. This is huge on a high specific power turbo engine.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
