b body axle length. help #2375893
09/24/17 01:24 PM
09/24/17 01:24 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
friend of mine needs a set of axles for a 66-7 b body. have a few sets that i measured and they are all way shorter than the axle length chart on here and other places. does anyone know the actual length of a 66-7 b body axle? (not the housing) i know the diff is 5/8" narrower vs 68-70 so axle length shorter as well i would assume.
can anyone help with a measurement so i don't give him the wrong ones?
edit. its an 8 3/4
Re: b body axle length. help [Re: chrisf] #2375894
09/24/17 01:26 PM
09/24/17 01:26 PM
Covington Georgia
RV2 Offline
RV2  Offline
Covington Georgia
Not sure if this will help you
Re: b body axle length. help [Re: chrisf] #2375898
09/24/17 01:38 PM
09/24/17 01:38 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
it would if he needed a dana. he has an 8 3/4 sorry didnt write that.
Re: b body axle length. help [Re: chrisf] #2375919
09/24/17 02:23 PM
09/24/17 02:23 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
28 7/8 from tech archives.Lots of info there.Rocky
Chrysler Firepower
Re: b body axle length. help [Re: chrisf] #2375922
09/24/17 02:28 PM
09/24/17 02:28 PM
British Columbia
chrisf Offline OP
chrisf  Offline OP
British Columbia
according to that chart i have 6 A body length factory 4.5" bolt pattern axles. wow, what are the chances?
Re: b body axle length. help [Re: chrisf] #2375934
09/24/17 02:47 PM
09/24/17 02:47 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I am drawing a blank as to what A body came with 4.5" bolt pattern 8 3/4's.
Don't be the exception.
Re: b body axle length. help [Re: chrisf] #2376019
09/24/17 06:53 PM
09/24/17 06:53 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
The number above is accurate at 28 7/8" from brake drum surface to end of splines. just measured one last week. 1965-1967 only.
