What valve springs should I get? #2374020
09/20/17 06:38 PM
09/20/17 06:38 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
400/470 motor with Eddy RPM heads and Howard's 574" lift solid flat tappet cam. The Eddy heads came with springs that only have 120 lbs. seat pressure. What would you suggest I get for replacement springs with this combo?
Re: What valve springs should I get? [Re: 440mopar] #2374072
09/20/17 07:53 PM
09/20/17 07:53 PM
Until someone chimes in with an exact recommendation in the meantime I would measure the open/closed heights and psi when open and coil bind/wipe pattern & the rest of the std checks to help with a baseline.
Re: What valve springs should I get? [Re: 440mopar] #2374075
09/20/17 07:59 PM
09/20/17 07:59 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Why don't u call Howard's & tell them what cam u have, they should tell u what springs r needed.
Re: What valve springs should I get? [Re: 440mopar] #2374150
09/20/17 09:36 PM
09/20/17 09:36 PM
crabman173
crabman173
Marsh uses a spring made by Isky that is PERFECT for that application call Moparts Connection and get hooked up
Or you could just buy a set of Comp inners --drop them on and keep rolling--yea which one--well I can't remember the number but they only sell three and two won't fit so do the research and get your problem solved for like $38
Re: What valve springs should I get? [Re: rickraw] #2374200
09/20/17 11:09 PM
09/20/17 11:09 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I did that. First, I called Edelbrock. They said I needed to talk to the cam manufacturer. So I called Howard's and they said I needed to talk to Edelbrock.
Re: What valve springs should I get? [Re: 440mopar] #2374202
09/20/17 11:13 PM
09/20/17 11:13 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Call Dwayne Porter.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: What valve springs should I get? [Re: B3422W5] #2374217
09/20/17 11:39 PM
09/20/17 11:39 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
I use the Comp 925 springs on those heads with a Mopar Performance .590 solid lift cam. I would also suggest that you go to a 10* retainer with those springs.
Brian
Re: What valve springs should I get? [Re: 440mopar] #2374220
09/20/17 11:41 PM
09/20/17 11:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using Isky forever........... thumbs
Re: What valve springs should I get? [Re: 440mopar] #2374890
09/22/17 05:02 AM
09/22/17 05:02 AM
Sweden
Mopar Guy Offline
Mopar Guy  Offline
Sweden
I also would recomend you to contakt Duane Porter at Porters Racing Heads ! You probably can buy al the stuff you need of him to work
Re: What valve springs should I get? [Re: 440mopar] #2375042
09/22/17 02:40 PM
09/22/17 02:40 PM
I have shimmed more than one set of stock springs on both the RPM heads and Stealth heads to use them on cams with less than .600 net lift to get 140 to 160 lbs. on the seat sand between 325 to 375 lbs. open pressures. I shoot for at least .060 to coil bind also when I'm done with setting them up up
I do have a older mechanical Rimac 1000 valve spring tester and a drawer full of valve spring shims so I use it and them to get all of the springs within 5 lbs. of each other on the seats up
On your deal you should probably be able to get the same good results if you can find a shop that has both of those tools in stock scope
Re: What valve springs should I get? [Re: Cab_Burge] #2375221
09/22/17 09:38 PM
09/22/17 09:38 PM
IN
ahy Offline
ahy  Offline
IN
I run Eddy's and think the base springs are a bit weak for that cam lift. It does depend on ramp speed and I suggest you call Howard's and talk to somebody else... they should be able to give a recommendation.
When I started pushing my fast rate .55" lift cam on the track I upgraded to a Comp double spring. Under 6000 RPM I was probably OK with the single Eddy spring but I occasionally ran it up to 6,500 and did not want to find out the hard way I needed more spring.
Re: What valve springs should I get? [Re: B3422W5] #2375304
09/23/17 01:15 AM
09/23/17 01:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Originally Posted By B3422W5
Call Dwayne Porter.
I agree as I bought my EZ heads from Dwayne which he set up and I believe he said he used Comp springs. My cam is a solid flat tappet thats .585 & .592 lift and they are not beehive springs. Dwayne is as good as you can get on heads and valvetrains so yes I would call him. 802-951-1955. Good luck , Ron
Re: What valve springs should I get? [Re: 440mopar] #2375315
09/23/17 01:50 AM
09/23/17 01:50 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Cam manufacturer should spec this for you based on ramp profiles, but just based on the lift dimension the OP gave and my rudimentary knowledge, something in the 150-175 seat and 350-375 open range should be about right.
Re: What valve springs should I get? [Re: StealthWedge67] #2375369
09/23/17 10:02 AM
09/23/17 10:02 AM
USA
440mopar Offline OP
440mopar  Offline OP
USA
It looks like I should be looking for a seat pressure of 150-160 lbs. for the cam I have. According to the spec sheet that came with my heads, the pre-installed springs are rated at 120 lbs. I looked on Summit's website at inner springs and they sell Comp inners in various pressures, heights, diameters, etc. What I noticed though is that all of the installed heights are less than the installed height of the springs on my heads (1.88") except for one that is 1.90" tall. Should the inner spring be the same height as the outer or are the inners typically a little shorter than the outers? How do I go about choosing an inner that is the correct height?
Re: What valve springs should I get? [Re: 440mopar] #2375499
09/23/17 02:49 PM
09/23/17 02:49 PM
The inners are always installed shorter than the outer due to the step on the retainers scope Measure the difference on the steps and go from there up
Do you have access to a valve spring tester? If so see about using shims on the ones you have first, take nothing for granite tsk
Re: What valve springs should I get? [Re: 440mopar] #2375528
09/23/17 03:33 PM
09/23/17 03:33 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Comp Cams 930-16 springs should work for your setup.
The only Carbs I care about are under the hood!
Re: What valve springs should I get? [Re: Azzkikrcuda] #2375713
09/23/17 10:35 PM
09/23/17 10:35 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
I'd rather not spend another $160 if I don't have to. If I can add inner springs for $40 I'd rather do that. Something like this. https://www.summitracing.com/parts/cca-973-16/applications
Re: What valve springs should I get? [Re: 440mopar] #2376440
09/25/17 01:42 PM
09/25/17 01:42 PM
USA
440mopar Offline OP
440mopar  Offline OP
USA
It looks like the Comp inner springs that I posted the link for in my last post should work based on the measurements I have taken of the pre-installed springs on my heads but I do have a couple more questions. The springs that came on my heads have a smaller flat metal spring inside them. If I buy the Comp inner springs, should the flat inner springs come out or should they be left and the new inners installed inside of them? Also, do you think I should replace the valve locks (7 degree) with 10 degree locks? I called Edelbrock and they told me it wouldn't be necessary but it seems like it would be a good idea.
