Re: What valve springs should I get?
[Re: 440mopar]
#2374072
09/20/17 07:53 PM
09/20/17 07:53 PM
RapidRobert
Until someone chimes in with an exact recommendation in the meantime I would measure the open/closed heights and psi when open and coil bind/wipe pattern & the rest of the std checks to help with a baseline.
[Re: 440mopar]
#2374150
09/20/17 09:36 PM
09/20/17 09:36 PM
crabman173
crabman173
Marsh uses a spring made by Isky that is PERFECT for that application call Moparts Connection and get hooked up Or you could just buy a set of Comp inners --drop them on and keep rolling--yea which one--well I can't remember the number but they only sell three and two won't fit so do the research and get your problem solved for like $38
[Re: rickraw]
#2374200
09/20/17 11:09 PM
09/20/17 11:09 PM
Posts: 732 USA
440mopar
USA
Why don't u call Howard's & tell them what cam u have, they should tell u what springs r needed. I did that. First, I called Edelbrock. They said I needed to talk to the cam manufacturer. So I called Howard's and they said I needed to talk to Edelbrock.
[Re: B3422W5]
#2374217
09/20/17 11:39 PM
09/20/17 11:39 PM
Posts: 2,042 Mooresburg, Tn
'72CudaRacer
Mooresburg, Tn
I use the Comp 925 springs on those heads with a Mopar Performance .590 solid lift cam. I would also suggest that you go to a 10* retainer with those springs.
Brian
[Re: 440mopar]
#2375042
09/22/17 02:40 PM
09/22/17 02:40 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
I have shimmed more than one set of stock springs on both the RPM heads and Stealth heads to use them on cams with less than .600 net lift to get 140 to 160 lbs. on the seat sand between 325 to 375 lbs. open pressures. I shoot for at least .060 to coil bind also when I'm done with setting them up I do have a older mechanical Rimac 1000 valve spring tester and a drawer full of valve spring shims so I use it and them to get all of the springs within 5 lbs. of each other on the seats On your deal you should probably be able to get the same good results if you can find a shop that has both of those tools in stock
[Re: 440mopar]
#2375315
09/23/17 01:50 AM
09/23/17 01:50 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Cam manufacturer should spec this for you based on ramp profiles, but just based on the lift dimension the OP gave and my rudimentary knowledge, something in the 150-175 seat and 350-375 open range should be about right.
[Re: 440mopar]
#2375499
09/23/17 02:49 PM
09/23/17 02:49 PM
Cab_Burge
The inners are always installed shorter than the outer due to the step on the retainers Measure the difference on the steps and go from there Do you have access to a valve spring tester? If so see about using shims on the ones you have first, take nothing for granite
[Re: 440mopar]
#2375528
09/23/17 03:33 PM
09/23/17 03:33 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Comp Cams 930-16 springs should work for your setup.
The only Carbs I care about are under the hood!
