Page 3 of 4 1 2 3 4
Re: Bracket Gen 3 Build [Re: sixpackgut] #2374190
09/20/17 10:53 PM
09/20/17 10:53 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
shruggy
Re: Bracket Gen 3 Build [Re: sixpackgut] #2374281
09/21/17 12:45 AM
09/21/17 12:45 AM
Out West
408strokerdart Offline OP
Out West
Originally Posted By sixpackgut
I dont believe you can shorten the runners. The setion between the runner where you would shorten it is hollow for the idle circuit maybe. Not sure about that
Brain, i have a friend. Get me the holley part #s and Ill get you prices. There are 2 prices, on your own or you can call with questions as much as you want
I will send you the parts list I got from the Holley guy. Give me a good email address again....
And thanks! I checked prices from Jegs and can save a little with my Pro discount, but it is still enough to make you faint.
Re: Bracket Gen 3 Build [Re: sixpackgut] #2374380
09/21/17 10:05 AM
09/21/17 10:05 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
The one that came with some other 6.1 parts, was cut down the middle length wise. and everything you see in this photo that would be under the base plate was removed.
I'll see if I can get the manifold back so I can take some photos of it.
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2374382
09/21/17 10:06 AM
09/21/17 10:06 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
yes this is your photo.....(I didn't have a6.1 photo on this computer)
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2374624
09/21/17 05:35 PM
09/21/17 05:35 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
I think the runner length on a 6.1 intake is 9 ish inches IIRC.
Mopar to the bone!!!
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2384970
10/10/17 10:39 AM
10/10/17 10:39 AM
Out West
Out West
Got my new 6.1 block, heads back from sixpakgut (Ray) and most of the other parts rounded up. The front of the intake is welded up and resurfaced for the TB adapter. Been working hard on the timing cover and making it ready for my cooling system. Also found a machine shop in the DFW are that has a torque plate for this thing so I won't have to buy one. Should be screwing this thing together in about 4 weeks (lead time on pistons). Pics to come when I put it together.
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2385001
10/10/17 11:42 AM
10/10/17 11:42 AM
Indianapolis In. usa
Quickrunner Offline
Quickrunner  Offline
Looking forward to seeing this come together.
05 Ram 1500 Daytona package
71 Demon Gen3 hemi drag radial project
Missin' my 9 second 70 runner!
Re: Bracket Gen 3 Build [Re: Quickrunner] #2398408
11/04/17 03:10 PM
11/04/17 03:10 PM
Washington State
cudaragtop Offline
cudaragtop  Offline
Washington State
Following.
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2402596
11/12/17 04:30 PM
11/12/17 04:30 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Have any new progress to report?
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2404488
11/16/17 02:21 PM
11/16/17 02:21 PM
Out West
Out West
Heads are done and assembled. I didn't like the stock valve job so we did a nice 5 angle job that picked up a few numbers on the flow. Also took a small surface pass to make a better finish to seal the deck. Set-up new springs and cleaned up.
Molnar crank and rods have arrived as well as the bearings. Custom Diamond pistons have arrived yesterday so the rotating assembly will be balanced on Friday (tomorrow).
Block work is just waiting on my new torque plate to arrive. (anyone building a gen 3 in DFW can "rent" my torque plate if they have the work done by Wells Racing Engines).
My timing cover will be done this weekend. Motor plate template is finished.
New custom Innovators West balancer is on order.
6.1 Intake has been extensively modified by me. Custom 3d printed adapter for the Holley Sniper LS throttle body to intake is in process.
Lots happening on this build. Should be putting everything together starting early to mid December.
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2404492
11/16/17 02:39 PM
11/16/17 02:39 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I for one can not wait to see what one of these suckers can do in a car like your’s. Counting down the days. Very nice quality build
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2404493
11/16/17 02:40 PM
11/16/17 02:40 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Pics would be nice
Re: Bracket Gen 3 Build [Re: pittsburghracer] #2404495
11/16/17 02:45 PM
11/16/17 02:45 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
With a flat hood hammer
Re: Bracket Gen 3 Build [Re: sixpackgut] #2404645
11/16/17 10:16 PM
11/16/17 10:16 PM
Out West
Out West
Yes, under a flat hood.
Re: Bracket Gen 3 Build [Re: sixpackgut] #2404646
11/16/17 10:17 PM
11/16/17 10:17 PM
Out West
Out West
Pics would be nice
Posting from my desktop at work. No picture hosting sites are work approved.
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2405098
11/17/17 06:04 PM
11/17/17 06:04 PM
Out West
Out West
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2405205
11/17/17 10:28 PM
11/17/17 10:28 PM
PA.
"Little"John
"Little"John
PA.
What the heck. That website asked if I was over 18 so I closed it out.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Bracket Gen 3 Build [Re: pittsburghracer] #2405674
11/18/17 10:06 PM
11/18/17 10:06 PM
Out West
Out West
Not sure what is going on so I changed hosting site.
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2405702
11/18/17 11:06 PM
11/18/17 11:06 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Brian's pics
Re: Bracket Gen 3 Build [Re: 408strokerdart] #2405847
11/19/17 10:04 AM
11/19/17 10:04 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
That ridge, have you found it works on the Eagle or 6.1 heads also?
Page 3 of 4 1 2 3 4
