keep wearing out my T&D rockers #2374597
09/21/17 04:26 PM
09/21/17 04:26 PM
Virginia Beach, VA
O
Old School Offline OP
O
Virginia Beach, VA
Like the title says, I keep wearing them out. I get maybe 4000 miles out of them. all on the street. Indy sr heads. solid roller .650" 272 276@.050. I use pac 1225 springs. these are also 1.6 rocker arms.
I do restrict the oil to the heads. I use a .040"
one on each head. Wondering if I should just remove them, and not use any at all.
The wear is not the shaft or the bearings. I think it is the aluminum bore of the rocker itself. They hold lash really well, but I can grab the rocker and twist it and get a lot of play. needles to say, they are loud and clacky. I use VR 1 20/50 for oil.
I just ordered a new set. Was thinking if a 1.5 might hold up a little better on the street. thoughts???
68 cuda formula S 588" bb 5sp
70 CUDA CONVERT 500" 5SP (SUBLIME)
70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: keep wearing out my T&D rockers [Re: Old School] #2374600
09/21/17 04:29 PM
09/21/17 04:29 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If its an option moving over to Hardlan Sharp may not be a bad idea. Lifetime warranty and free inspections.
68 Barracuda Formula S 340
Re: keep wearing out my T&D rockers [Re: Old School] #2374605
09/21/17 04:40 PM
09/21/17 04:40 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Shaft or individuals
edit
cam is very close to what you have..never wore out a rocker
yet... I think you are side loading them or they are twisting
wave
Re: keep wearing out my T&D rockers [Re: Old School] #2374612
09/21/17 04:58 PM
09/21/17 04:58 PM
Norfolk, NE
Racer33 Offline
Racer33  Offline
Norfolk, NE
Are the heads oiled full time or only when the cam holes line up?
With restrictors I would think you want full time oiling.
Re: keep wearing out my T&D rockers [Re: Old School] #2374614
09/21/17 05:02 PM
09/21/17 05:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Have you talked with T&D about those spring loads and long term street duty?
IMO, it's way more spring than I'd run on a motor that sees primarily(or only) street use.
Smoother cam lobes, less spring pressure...... Things just last longer.
Re: keep wearing out my T&D rockers [Re: Racer33] #2374615
09/21/17 05:03 PM
09/21/17 05:03 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
SR heads are full time oiling.
69 GTX 68 Road Runner
Re: keep wearing out my T&D rockers [Re: Old School] #2374622
09/21/17 05:30 PM
09/21/17 05:30 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
You don't want to remove the restrictor. You may want to increase the size though. We run .046 restrictors in the 440-1's on our race engine. You may need to go a little larger than that if the engine is mostly street driven though.
Re: keep wearing out my T&D rockers [Re: Old School] #2374623
09/21/17 05:35 PM
09/21/17 05:35 PM
America
WedgeFED Offline
WedgeFED  Offline
America
T&D will rebuild the set of rockers for 100$ last time I talked to them. Very good customer service for sure, call them...
Re: keep wearing out my T&D rockers [Re: Old School] #2374628
09/21/17 05:39 PM
09/21/17 05:39 PM
AndyF Online content
AndyF  Online Content
As Dwayne says you might consider changing the cam lobe to something slower and then dropping the spring pressure down a bunch. If you get the correct lobe in there you might not even notice much of a difference in power.
Re: keep wearing out my T&D rockers [Re: Old School] #2374673
09/21/17 06:39 PM
09/21/17 06:39 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
IF you are running on the street, i fail to see why you would restrict the oil to the rockers. MORE is better. I know others will say to restrict it. BUT if you have enough for the mains and rods, then keep the heads well oiled. I found my springs lived a lot longer too.
Just my 2 Cents worth from another old school racer.
Old Geezer Racing
Re: keep wearing out my T&D rockers [Re: Old School] #2374678
09/21/17 06:43 PM
09/21/17 06:43 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
INDY SR heads use the external oil feed fed from the back of the block - you have too run a restrictor or you will pump way to much oil up top - for the street I would use the 0.060 pill in the lines.
Re: keep wearing out my T&D rockers [Re: MR_P_BODY] #2374688
09/21/17 07:08 PM
09/21/17 07:08 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
edit
wave
I don't see how I could be side loading them. It's a zero offset exhaust rocker. And the intake is only .250 offset.
Re: keep wearing out my T&D rockers [Re: WedgeFED] #2374689
09/21/17 07:11 PM
09/21/17 07:11 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
I talked with Shelton over at T&D. They can rebuild them only if the rocker body bores are not wore out. He thinks that's what's wrong with mine so there are no rebuilding them.
Re: keep wearing out my T&D rockers [Re: Old School] #2374697
09/21/17 07:23 PM
09/21/17 07:23 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
On one of my Motors I use the jesel paired rocker arms. I use more spring and .800 inch lift, streetcar also. I bet I've had the same rockers since the late 90s. And those are only spray bar oiled...😕
Re: keep wearing out my T&D rockers [Re: Old School] #2374701
09/21/17 07:52 PM
09/21/17 07:52 PM
nc
E
earthmover Offline
earthmover  Offline
E
nc
Send t&d the set let them look them over see what's going on..
Re: keep wearing out my T&D rockers [Re: Old School] #2374707
09/21/17 08:11 PM
09/21/17 08:11 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Sounds like instead of continuing to have the same part fail, get Jesels for this motor too.
Had a set of Jesel sportsman series on a 700 lift roller for 8 years with nary a problem, street driven too. New owner has now been running them 6 or 7 years with zero issues.
For something with a big roller i wouldnt use anything but Jesel
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: keep wearing out my T&D rockers [Re: earthmover] #2375002
09/22/17 01:05 PM
09/22/17 01:05 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
My thought, too. I'd want to know WHY they're experiencing that level of wear (excessive spring loads, insufficient lubrication, ???). shocked
Re: keep wearing out my T&D rockers [Re: Old School] #2375011
09/22/17 01:17 PM
09/22/17 01:17 PM
So. Burlington, Vt.
So. Burlington, Vt.
If the bores in the bodies are getting distorted, it isn't "wear"...... It's fatigue.
Re: keep wearing out my T&D rockers [Re: Old School] #2375097
09/22/17 04:19 PM
09/22/17 04:19 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Push the bearings out and measure the body. Mine were all with-in .0005".
Doug
Re: keep wearing out my T&D rockers [Re: dvw] #2375131
09/22/17 05:51 PM
09/22/17 05:51 PM
Virginia Beach, VA
O
O
Virginia Beach, VA
I'm going to send them a set back and see what they say. Would going from 1.6 to 1.5 take a lot of load off of the rocker arm fulcrum?
These motors that keep wearing out the rocker arms, all have solid roller cams. I used the Indy R1 cam. I think that is already a fast lobe maybe I'm overdoing it with a 1.6 ratio....
