keep wearing out my T&D rockers
#2374597
09/21/17 04:26 PM
09/21/17 04:26 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
Like the title says, I keep wearing them out. I get maybe 4000 miles out of them. all on the street. Indy sr heads. solid roller .650" 272 276@.050. I use pac 1225 springs. these are also 1.6 rocker arms.
I do restrict the oil to the heads. I use a .040" one on each head. Wondering if I should just remove them, and not use any at all.
The wear is not the shaft or the bearings. I think it is the aluminum bore of the rocker itself. They hold lash really well, but I can grab the rocker and twist it and get a lot of play. needles to say, they are loud and clacky. I use VR 1 20/50 for oil.
I just ordered a new set. Was thinking if a 1.5 might hold up a little better on the street. thoughts???
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
Re: keep wearing out my T&D rockers
[Re: Old School]
#2374600
09/21/17 04:29 PM
09/21/17 04:29 PM
Posts: 8,027 Tulsa OK
Bad340fish
Tulsa OK
If its an option moving over to Hardlan Sharp may not be a bad idea. Lifetime warranty and free inspections.
68 Barracuda Formula S 340
[Re: Old School]
#2374605
09/21/17 04:40 PM
09/21/17 04:40 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Shaft or individuals edit cam is very close to what you have..never wore out a rocker yet... I think you are side loading them or they are twisting
[Re: Old School]
#2374614
09/21/17 05:02 PM
09/21/17 05:02 PM
Posts: 14,498 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Have you talked with T&D about those spring loads and long term street duty?
IMO, it's way more spring than I'd run on a motor that sees primarily(or only) street use.
Smoother cam lobes, less spring pressure...... Things just last longer.
[Re: Racer33]
#2374615
09/21/17 05:03 PM
09/21/17 05:03 PM
Posts: 10,022 MN
JERICOGTX
MN
Are the heads oiled full time or only when the cam holes line up? With restrictors I would think you want full time oiling. SR heads are full time oiling.
69 GTX
68 Road Runner
[Re: Old School]
#2374673
09/21/17 06:39 PM
09/21/17 06:39 PM
Posts: 1,505 TN
SCATPACK 1
TN
IF you are running on the street, i fail to see why you would restrict the oil to the rockers. MORE is better. I know others will say to restrict it. BUT if you have enough for the mains and rods, then keep the heads well oiled. I found my springs lived a lot longer too. Just my 2 Cents worth from another old school racer.
Old Geezer Racing
[Re: MR_P_BODY]
#2374688
09/21/17 07:08 PM
09/21/17 07:08 PM
Old School
Virginia Beach, VA
Shaft or individuals edit cam is very close to what you have..never wore out a rocker yet... I think you are side loading them or they are twisting I don't see how I could be side loading them. It's a zero offset exhaust rocker. And the intake is only .250 offset.
[Re: WedgeFED]
#2374689
09/21/17 07:11 PM
09/21/17 07:11 PM
Old School
Virginia Beach, VA
T&D will rebuild the set of rockers for 100$ last time I talked to them. Very good customer service for sure, call them... I talked with Shelton over at T&D. They can rebuild them only if the rocker body bores are not wore out. He thinks that's what's wrong with mine so there are no rebuilding them.
[Re: Old School]
#2374697
09/21/17 07:23 PM
09/21/17 07:23 PM
Old School
Virginia Beach, VA
On one of my Motors I use the jesel paired rocker arms. I use more spring and .800 inch lift, streetcar also. I bet I've had the same rockers since the late 90s. And those are only spray bar oiled...😕
[Re: Old School]
#2374707
09/21/17 08:11 PM
09/21/17 08:11 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
Sounds like instead of continuing to have the same part fail, get Jesels for this motor too. Had a set of Jesel sportsman series on a 700 lift roller for 8 years with nary a problem, street driven too. New owner has now been running them 6 or 7 years with zero issues. For something with a big roller i wouldnt use anything but Jesel
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Old School]
#2375011
09/22/17 01:17 PM
09/22/17 01:17 PM
fast68plymouth
So. Burlington, Vt.
If the bores in the bodies are getting distorted, it isn't "wear"...... It's fatigue.
[Re: dvw]
#2375131
09/22/17 05:51 PM
09/22/17 05:51 PM
Old School
Virginia Beach, VA
I'm going to send them a set back and see what they say. Would going from 1.6 to 1.5 take a lot of load off of the rocker arm fulcrum?
These motors that keep wearing out the rocker arms, all have solid roller cams. I used the Indy R1 cam. I think that is already a fast lobe maybe I'm overdoing it with a 1.6 ratio....
