Fired up the engine today #237358
02/26/09 08:14 PM
02/26/09 08:14 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I fired up my race engine in the Dart for the first time this year. It was a cold February, but it got over 50 degrees today, so I fired it up after work. It felt good to see it go without a hitch. The only change from last year was I freshened the transmission and converter.
No changes, yet. Just fired it up to circulate the oil, warm up everything and put the race oil in for the upcoming season. The local track opens for testing Mar 7 (weather permitting), and the regular bracket races start the first weekend in April.
Now I will take the carburetor setup off and put this Ron's Flying Toilet injection system on for this year. I plan to test with methanol (race alky) for March. At some point when summer grade E85 is available, I plan to recalibrate the system for E85.
Re: Fired up the engine today [Re: 440Jim] #237359
02/26/09 08:23 PM
02/26/09 08:23 PM
sc
tjmarcus1 Online content
tjmarcus1  Online Content
sc
jim, i am interested in hearing how your car does with the methanol setup. and, what cfm is the t-body?
Re: Fired up the engine today [Re: 440Jim] #237360
02/26/09 08:38 PM
02/26/09 08:38 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Can`t wait to hear the results. Curious; how often do you freshen a converter and what does it consist of. Thankxx Jim.......
Re: Fired up the engine today [Re: tjmarcus1] #237361
02/26/09 08:40 PM
02/26/09 08:40 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
This is the big toilet, 4.1" rated 1800 cfm!
I think the 511 CID will like it. It really liked the Dominator carb compared to the 950 carb (small venturi).
From Ron's web site:
Flying Toilet throttle body is slot-machined to fit a 4500 (Dominator) or 4150 (Holley) flanged manifolds.
3-3/4" 1240 CFM
4" 1435 CFM
4.100" 1800 CFM
The smaller throttle body (3-3/4" - 1240 CFM) is reserved for 327 to 383 cubic inch engines where the owner has no plans of going bigger in cubic inch in the years to come. This throttle body typically is utilized with a "0" pump and .029-.035 nozzle jets.
The middle throttle body which is the most popular by far is the 4" version (1435 CFM). This has a wide span of cubic inch compatability ranging from 355 to as much as 502. This throttle body can work with a "0" or "0-1/2" pump and .032-.037 nozzle jets.
The biggest throttle body comes in at 1800 CFM (4.100") and is set aside for the bigger cubic inch/higher horsepower applications. Engines from 421 to 572 cubic inches can put this throttle body to work. Typically this throttle body will be mated with a "0-1/2" pump that will feed approximately 1000 HP with as big as a .040 nozzle jet.
http://www.ronsfuel.com/
http://www.killerrons.com/
Re: Fired up the engine today [Re: Thumperdart] #237362
02/26/09 08:44 PM
02/26/09 08:44 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I am not the man to answer that, it is a topic on its own. But I don't normally do it for years...
Re: Fired up the engine today [Re: 440Jim] #237363
02/26/09 08:48 PM
02/26/09 08:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Just curious as I`m lookin towards converter issues to explain why my car lays over in high gear. Thankxx.
Re: Fired up the engine today [Re: 440Jim] #237364
02/26/09 08:49 PM
02/26/09 08:49 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
what's your local track Jim?
Re: Fired up the engine today [Re: 440Jim] #237365
02/26/09 08:50 PM
02/26/09 08:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I was in the trailer and played with the car, I set
the lash and was going to fire it today but I was
working on the truck also.... was nice and warm today.
Glad to see you got yours fired up Jim
Re: Fired up the engine today [Re: jamesc] #237366
02/26/09 08:51 PM
02/26/09 08:51 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Maryland International Raceway (MIR), in Budds Creek Maryland.
http://www.mirdrag.com
Re: Fired up the engine today [Re: 440Jim] #237367
02/26/09 08:51 PM
02/26/09 08:51 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Good Luck w/ it Jim, curious to here the numbers when you get it on Alky...I made the switch to a toilet about 3 years ago, and will never switch back...
Curtis
Taking over the World one win light at a time.
Re: Fired up the engine today [Re: afxcoronet] #237368
02/26/09 09:04 PM
02/26/09 09:04 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Curtis, what improvement did you see on your car? What did you change from, and what size engine?
Re: Fired up the engine today [Re: 440Jim] #237369
02/26/09 09:37 PM
02/26/09 09:37 PM
Lehigh Acres, Florida
rickstershemi Offline
Best of Luck this season Jim...
Rickster
Re: Fired up the engine today [Re: rickstershemi] #237370
02/26/09 09:37 PM
02/26/09 09:37 PM
Awesome! Best of luck this season
Re: Fired up the engine today #237371
02/26/09 10:07 PM
02/26/09 10:07 PM
Cleveland
sunroofgtx Offline
sunroofgtx  Offline
Cleveland
Take lots of notes, Jim. Can't wait to see all of the changes and the differences they each make. Good luck !..
Join the quickest team in motorsports. Team FireCore. CustomWiresets.com
Re: Fired up the engine today [Re: tjmarcus1] #237372
03/02/09 11:03 AM
03/02/09 11:03 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
X2....that motor/car just plain ROCKS!
Re: Fired up the engine today [Re: EvilB1Dart] #237373
03/02/09 11:21 AM
03/02/09 11:21 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am sure you are itching to get out there and run it. One of those issues with Winter I suppose. Looking forward to hearing how the toilet works out as well. Good luck this year.
Re: Fired up the engine today [Re: Al_Alguire] #237374
03/08/09 09:15 PM
03/08/09 09:15 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Well, it went from a snow storm to 70 degrees this weekend. So I put the flying toilet injection system on the engine and fired it up. This was with race alky (methanol). It went well. No leaks, no problems. I took some Air/Fuel ratio measurements with my LM-1 while in the garage, and it looks to be in the ball park, ready for tuning at the track. I even did some foot braking to see how the A/F ratio changed with throttle position and some load. The real test is running WOT down the track.
A nice day with some accomplishment and no problems. That makes me happy.!
And yes, the burning alcohol fumes in the garage are terrible...
I plan to switch to E85, much cleaner burning. But that might not be for a couple months of racing. I added collector extensions with turn-outs, so the fumes during the waterbox burnout etc will not be under the car. But in the garage even with a fan blowing out... burns the eyes.
Re: Fired up the engine today [Re: 440Jim] #237375
03/08/09 10:21 PM
03/08/09 10:21 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Bet you are getting anxious to get at it now for sure. I have always wanted to run a Terminator system just never done it. Guess I am scared of em. Cant wait to hear the results.
Re: Fired up the engine today [Re: Al_Alguire] #237376
03/08/09 10:37 PM
03/08/09 10:37 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Congrats Jim, can't wait to see the results.
I gotta admit, I dread being next to alcohol cars in the staging lanes, I've often worried about dying while waiting our turn to move up. LOL
